S3 rev hang-up
S3DCT Oct 18, 2003
  1. S3DCT
    S3DCT New Member
    Problem : Accelerate briskly, change up 1st to 2nd, revs hang or increase! 2nd to 3rd revs hang or increase again, same 3rd to 4th, and this is with full lift-off the loud pedal! Makes you feel like a learner but I've been scorching around in cars and on bikes for 40 years,
    don't label me an old f*rt, look at the ages of the best sports/endurance racers (age, not size, of the b*lls counts).
    Back to the issue : the only way to stop the motor reving on as you change up is to take a full second for each gear change to allow the revs to drop a little, defeating the object of a brisk car.
    My local dealer claims 'they all do that sir to keep the turbo spinning'. Well the few I tried before buying didn't, nor did mine 'til the last service.
    When I'm a biker and I ease the throttle a bit to sync the revs on an up change I expect (and get!) the engine to respond.
    Is my S3, Jan'01, a freak? or do any of you guys also suffer this problem?
  2. mramage
    mramage Member
    516
    Erm, that does't sound right. The revs certainly drop off on mine between changes. Get the dealer to take you out in another car or get a tech to come out with you and demonstrate the problem. Don't let them off with it /ubbthreads/images/graemlins/smile.gif
    I had a car that used to do that and it got the lambda sensor changed. Not saying it's that, but it certainly doesn't sound right.
    Your car wouldn't be purple by any chance? Sure I saw a purple S3 with a similar reg the other day, meant to post on spotters forum.
  3. MarkS3
    MarkS3 Member
    mine does the same but only if i change up on full throttle at about 4k revs if i take it to 5k plus it does not do it!! /ubbthreads/images/graemlins/groovy.gif
  4. AndyS3
    AndyS3 Member
    133
    There's a switch on the clutch or the accelorator pedal cant remember which one, it can stick and the revs will hold after life off. Have a search of the forum i have read about it before not sure which forum i read about it on might have been tt forum worth a look.
    Good luck
  5. audi_girl
    audi_girl Active Member
    1,038
    My rev's hang for a bit - drive along and put your foot on the clutch and they just hover for a noticeable time before dropping.
    I figured it was just a (bad) characteristic of the car!
  6. AL_B
    AL_B Well-Known Member
    1,724
    171
    Perhaps you guys need a throttle body re-alignment. It can be done via a VAG COM IIRC.
    AL
  7. pure
    pure Member
    340
    mine doesn't do that, full throtle, press clutch and come off the gas, revs drop, change gear, gas....and away I go /ubbthreads/images/graemlins/laugh.gif
  8. MingBluS3
    MingBluS3 Member
    360
    Mine does the same as your's Audi Girl. Like you say it depends on whether the car is in drive or not, stationary out of gear its no problem , but in gear you notice the revs don't drop off as fast..
    verdict : ****
  9. audi_girl
    1,038
    Out of gear it's the same - like when changing gear :-S
  10. MingBluS3
    MingBluS3 Member
    360
    Nah i only notice this when i'm stationary and revving the engine in frustration (due to excessive traffic in London)
  11. RichA3Turbo
    5,089
    My A3 does exactly the same thing... was wondering if it was normal just the other day!
    Rich
  12. domcj
    domcj Member
    50
    Has anyone who has this problem looked into it anymore or fould the fault or cure ?
  13. bjacks
    bjacks Member
    78
    MAF replacement helped, although that's not why I replaced my MAF - it was an added bonus /ubbthreads/images/graemlins/grin.gif
    At over £200 a pop, not something to be tried without proper diagnosis, or swap the sensor over with a known good one.
    Ben
  14. domcj
    domcj Member
    50
    I have benn to see a freind of mine and he is a ex Audi tech, he says that the flap in the throttle housing gets a bit of gunk around the edges and this can cause the problems so I am going to remove it when i get a chance and then he said he would set it up on vag-com for me.
