S3 Rear Diff Oil Change
jonS3 Feb 6, 2007
  1. jonS3
    jonS3 Member
    719
    Right, I now know that it needs to be a 75w90 GL5 oil in the rear diff, but before I start, does anyone know what tool is needed to remove the drain plug and filler plug?
    cheers
    Jon
  2. markyp2002
    markyp2002 Member
    311
    If its anything like the diffs i make the drain plug will be a square centred grub screw (relatively big one)
    as for the oil, make sure you get Castrol 75w90 Synthetic transmission oil - its the best type to use.
  3. simch
    simch Active Member
    2,028
    And mine took Three litres according to my invoice form APS! I thought here was only a litre in there...! So make sure you have enough! It takes a while to drain to, about 30 minutes or so!
  4. fdussud
    fdussud Member
    40
    Have a look on the VAG Parts LTD website. They sell the tool needed to remove the filter as well as oil and new filter.
  5. jonS3
    jonS3 Member
    719
    there's no filter on the rear diff. are you thinking of the haldex oil and filter?
