S3 rattle?
IbisJake Mar 17, 2014
  1. IbisJake
    IbisJake Member
    35
    Understand these aren't the quietest of engines, but on cold start ups the engine seems to rattle more before the idle settles down. Sounds more like a belt rattle than anything, also when stationary and revved to around 2000 rpm it seems a bit tinny as well, past this it seems fine, any suggestions or am I just being paranoid?
  2. Boydie
    Boydie Boycie VCDS Map User
    3,285
    394
    If you are concerned, take it to a reputable garage and get it checked out. Mine makes noise as well but it is coming from the flywheel :(
  3. IbisJake
    IbisJake Member
    35
    Just had her serviced at Audi and wasn't flagged up, just wondered how normal this was?
  4. Boydie
    3,285
    394
    If you are concerned, say to Audi this occured after their service....
  5. IbisJake
    IbisJake Member
    35
    Think thats best way mate, they're having a look in morning, have a feeling its going to be a belt tensioner or something similar!
  6. IbisJake
    IbisJake Member
    35
    Just for reference if anyone else ever has same problem, it turned out to be the cambelt tensioner so replaced everything as would need doing toward end of this year anyway.
  7. Keane
    Keane Active Member
    458
    66
    Omg ! I've had this after I got my Audi's cambelt changed !! Been driving me mad... I'm gonna phone Audi Tomo.
  8. IbisJake
    IbisJake Member
    35
    Funny you should say this as it has gotten rid of the rattle but does now seem to make a almost nocking "bassy" noise on idle which wasn't there before, may however be me trying to create problems!
  9. Keane
    Keane Active Member
    458
    66
    Did it sound like a tappet ? Mine seams too disappear after 2k revs. It was 100% after cambelt was changed.
  10. IbisJake
    IbisJake Member
    35
    Sounds exactly like the rattle i had, was really strong right up to 1800rpm then disappeared completely.
  11. Keane
    Keane Active Member
    458
    66
    Yes that's exactly the same as my s3. Can tell it's not engine noise and was after I had the cambelt changed so I'm sure it's this also ! Cheers bud
  12. IbisJake
    IbisJake Member
    35
    Let me know how you get on, hope your local Audi are as good as mine!
  13. Keane
    Keane Active Member
    458
    66
    They do seam alright. How did they come about finding the problem ? Or just know straight away?
  14. IbisJake
    IbisJake Member
    35
    Took the car to them, they then called stating the noise was coming from inside cambelt casing and that they would suggest changing belt, tensioners and water pump, collected it after and all was fine!
  15. Keane
    Keane Active Member
    458
    66
    Did you have the cambelt changed also? I'm just hoping they don't try too avoid the situation as I KNOW this was after it got changed but it's defo getting worse.
  16. IbisJake
    IbisJake Member
    35
    Get it booked in, if you say the problem occurred afterwards they will have a look for free and then depending on their decision after that as to wether they cover costs or you do i guess.
  17. Keane
    Keane Active Member
    458
    66
    Yeah will do. Cheers bud
