S3 rad ...
motfree Nov 29, 2010
  1. motfree
    motfree Member
    464
    Driving to work today temp sign comes up on dash anyways pull over to check coolant but therea nothing there ... Radiator has a crack and it's ******* out ..
    Need a new 1 asap anyone know the best place to go to get a new 1 ?
  2. bengal
    bengal Member
    537
    You do have some problems dont you i feel for you though. In the past iv always got mine from radiator specialists as they are good quality and prices but obviously im not in your area im sure someone more experienced will advise as i havnt had to do mine yet.
  3. <tuffty/>
    21,885
    4,203
    Define best place?
    GSF, TPS and a VAG dealer would be first port of call... in that order :)
    Assuming the S3 uses the same rad as the rest of the 20v turbo's then GSF list one for £46+vat
  4. motfree
    motfree Member
    464
    Got 1 for £39 :-D
    Tell me about it problem after problem .. Other car has a crack in the sump aswel haha
    They easy to fit or is it up in the air job ??
  5. bengal
    bengal Member
    537
    I take it you mean the radiator iv not done one on these or thought about it but i would imagine you have to take the bumper off if im wrong then it will be easier as you would just do it from under the bonnet no need to put it on a lift or ramps. Hopefully someone whos done one on these will be able to tell you more.
  6. motfree
    motfree Member
    464
    Hopefully someone can advise me :)
