S3 Quattro & TT Quattro suspension - Are they identical?
Welly Jun 15, 2010
  1. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    As title, just wondering.....
    I.E. Could you but a suspension kit for a TT Quattro and fit it to an S3 Quattro?
  2. Westy
    Westy Well-Known Member
    17,443
    1,103
    I've seen a few posts regarding this recently but nobody has actually cleared it up. I'd like to know too because a lot of the TT kits are cheaper than the S3 kits.
  3. Welly
    10,696
    127
    Exactly the reason I ask..... :thumbsup:
  4. Westy
    17,443
    1,103
    I have a feeling that they are not the same but would like to hear it from someone who knows. If they are compatible I'll put my suspension order in tomorrow :o.k:
  5. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    That makes two of us. Or three actually.
  6. sportstractor
    sportstractor Chugger
    2,709
    only way to find out is to check with audi to see if part numbers match. They probably dont
  7. jojo
    28,856
    3,516
    The rear is the same I believe, but the fronts are different. The S3 has slotted front suspension arms which allows for camber adjustment and has a slightly wider track to fill those wider arches I believe, not 100% sure on the rear though...
  8. Chlippo
    Chlippo Member
    679
    15
    I usually face this problem every single time i want to buy any piece for my S3 since S3 8L wasnt introduced in the USA and no one is able to really answer those questions on TT and S3 fitments. One thing i am 90% sure of is that the springs, shocks, arb's, brakes and downpipe will fit.
    Here is the kit i was going to order, i consider this a pretty much good deal. 850$ for the shocks and the ARB's is a good price?
  9. mad max
    mad max sixth gear
    338
    could try waks website ask him the same question www.wak-tt.com a mine of info on here a lot of it relavant for our cars
  10. jojo
    28,856
    3,516
    You need parts for a Mk1 TT225 when it comes to suspension components and engine tuning, it should all fit.
  11. Matt82
    Matt82 Active Member
    2,365
    front and rear dampers are the same number with KW suspension
    looks like the spring rates may be different though
  12. Chlippo
    Chlippo Member
    679
    15
    When i contacted "Koni" they confirmed that the suspension parts they make for TT quattro and S3 quattro are the same, same fitting same spec,
    Part number might be different but it is the same part.
    For example, i think bilstein sport damps fits on mercedes S and CL class...i read that on a seller site somewhere
  13. Westy
    17,443
    1,103
    Right then Welly, as you are the ASN ginea pig I think you need to purchase a TT suspension kit and see if it fits :p
  14. Matt82
    2,365
    this does sound like a job for Welly tbh
    it sounds like itll all fit on but the spring rates may be different, but i cant say how different
  15. Welly
    10,696
    127
    OK, may well give it a go. Will have some dosh at the end of the month when the Blue S3 gets gone, so I'll be on it like Sonic.
    This is the kit I have been looking at. I've had nothing but good experience with PI shocks & springs in the past so am happy to go with them again.
    http://www.carperformanceuk.co.uk/t...kit-that-lowers-25mm-c-9350-p-2-pr-30152.html
    Plus this company is in Sharpness Docks, which I can see from my house, so will go and collect from them!
  16. Westy
    17,443
    1,103
    Good man :thumbsup:
    Will you be purchasing some adjustable tie bars too?
  17. Welly
    10,696
    127
    Will I f**k. I don't believe in them. Give me rubbish camber any day..... That can at least be the testing for that other thread on which we were all discussing rear camber!
    'We is nobbin 2 birds with 1 connie innit'
  18. JD09
    3,096
    46
    Lol.
    + Two thanks for you for a; being a little furry animal that people run tests on and b; for changing the Homer quote!
  19. Welly
    10,696
    127
    No problem dude! :thumbsup:
  20. mk1chopper
    mk1chopper Missing the S3
    1,092
    TTS said I could use TT shocks on my S3, and after market springs. I dont think you can use oem TT springs as theres about 8 differnent types depending on which model you have. Ess3 confirmed that the neuspeed ARB's listed for the TT quattro will fit the S3 (Awesome GTI conformed this).
  21. Westy
    17,443
    1,103
    Welly you complete Leg End. ASN collectively owes you many beers. :beerchug:
  22. StevoS3
    StevoS3 Member
    217
    wow u'd of thought poeople would know this by now on here...
    Im all up for gettin welly a couple beers :) that little wiskered beast!
  23. Welly
    10,696
    127
    No worries guys, I don't mind piloting things to be honest.
    I don't see why they wouldn't fit to be fair, I would check vag cat but it's been broke for ages now and I can't get on it which sucks :(.
    If they don't, then I'll just sling them on ebay!
  24. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    get your adjustable camber links, as well, or you may as well have bought the s3 kit, with the tyres you are going to trash....:ermm:
  25. Welly
    10,696
    127
  26. JD09
    3,096
    46
    Interesting. I would be tempted to go with Awesome's answers . . .
  27. Welly
    10,696
    127
    I would normally agree. But, those guys are right, the part numbers are identical....
    Don't know what to do now really.... Hmmmmm.
  28. Welly
    10,696
    127
    To be fair, not many suspension manufacturers actually do a suspension kit for the S3 at all, and I can't understand why!
  29. DPM
    DPM Site Sponsor Site Sponsor
    4,987
    200
    No they're not identical.
    The dampers will most likely be deopending on make but the springs won't. The TT is lighter so spring rates will be different.
    Damian @ DPM Performance
  30. Welly
    10,696
    127
    Thanks for clearing that up mate - makes life a lot easier.
    Its great to have a discussion about it, but none of us really know, where as you do!
    :thumbsup:
  31. DPM
    4,987
    200
    :thumbsup:
  32. m8arx
    m8arx Member
    176
    does that mean the TT shocks can be used with standard S3 springs (or eibach one's if wanted to go lower)???
  33. jojo
    28,856
    3,516
    You need ones that are made for the 225 TT Quattro(and probably V6 version), any other model TT below it has different front suspension.
