S3 PE1820 big turbo build
Welly Mar 29, 2011
  1. superkarl
    superkarl MAN OF STEEL
    9,428
    2,398
    I got one off the bay too, good quality, had a logo that read 'topran' on it.
    What sort of figures does the turbo produce on similarly displaced engines?
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    That's exactly the same sump I just ordered, a Topran one. Seemed OK, so meh. lol.
    I suspect it should make up to 380 ish with a bit of luck, fingers crossed.
  3. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    Bargain!
    Thats pretty awesome that you got to drive it home! good starting point power wise shame mines not ready for a quick comparison :ninja:
  4. Welly
    10,696
    127
    Bill did some comparisons on the dyno PC, and the PE's output wasn't looking that hot to be fair when compared to the hybrid's.
    It doesn't drive like that though, I was really impressed.
    Hopefully Bill can pop the dyno prints up when he has 2.
  5. Westy
    Westy Well-Known Member
    17,443
    1,103
    Lovely stuff Welly I'm looking forward to seeing yours and Dane's builds when they're complete.
  6. Welly
    10,696
    127
    Yeah, will be good to see another hybrid car I must admit. :)
    Hoping I'm not going to regret the change, however based on what it feels like now, I don't think I will.
    Can't wait to see the finished product I must admit.
  7. superkarl
    9,428
    2,398
    I really wana go hybrid now for the constant power youve mentioned. All these turbo build threads are frankly pissin me off, lol, they influence me too much!
  8. Welly
    10,696
    127
    Yeah, the hybrid was a very good all rounder, let there be no doubt. However I did suffer some fairly constant issues running it as highly strung as I was, and that was what eventually made me head down the larger turbo route. I've been through so many manifolds, and get so much ear ache... lol
  9. superkarl
    9,428
    2,398
    Thanks to you pushing it other people can avoid some problems. It was that shitty 034 mani that ruined it for you. Roughly how much more will an ihi conversion be compared to hybrid?
  10. Welly
    10,696
    127
    Hard to say mate if I'm honest - most of the work was done already so it's hard to get a feeling for it. When it's all finished I will try and work it out me thinks.
  11. Welly
    10,696
    127
    Yeah, not the best product I have ever seen. And no mention of the 'revised' one.... and that was 6 months ago now....
    Revised my arse.
  12. badger5
    9,429
    1,974
    a difference which would effect spool/load on sunday was I ran it in 4th, where all comparisons were in 5th previously. this shifts the torque/spool to the left on the plots with less load applied. I am at the max roller speed in 5th with your 7800rpm limiter, so I ran it in 4th.. but next time I will compare to 5th again, and see how the next ramp rate and 4th compares load wise. Balance of sufficient load but not too much load for the engine to work against, without getting all hot and bothered.
  13. Welly
    10,696
    127
    OK dude, sounds good to me.
  14. Welly
    10,696
    127
    OK - sump sorted for now, well until the new one arrives. I'm not sure I will be seeing it this week, so I couldn't wait that long.
    Managed to resolve the leaking, long story, which I can't be arsed to describe in honesty.... lol.
    Anyway, fuel pump wiring finished - bumper refitted - leaks sorted.
    Ready for mapping :)
    The K04 hybrid map is performing outstandingly well considering it is running the PE1820 on it. As said before, fueling is very rich currently, however she is still managing to make 268 g/s flow at 22.3 PSI, so not bad.
    Planned boost is going to be 25-26 PSI, fueling hopefully around the 12.5 mark.
    We shall see what she does....
  15. s3 Hoggy
    s3 Hoggy Whats going on???
    1,716
    158
    Good man Welly! Impatience is a virtue!
  16. Welly
    10,696
    127
    I don't know what you're talking about.... :whistle2:
  17. Dane
    4,086
    182
    He leaves me for dead... Easily... You can tell it spools up later though.
  18. Welly
    10,696
    127
    A photo of the finished product:
  19. Welly
    10,696
    127
    Yeah, agree completely, the lag is much more apparent. However that wasn't completely unexpected, and hopefully clipping some fuel out will help the spool a little.
    I'm back on MBC control only now at 22 PSI for the time being, that seems to have helped the lag a little.
  20. Andrew@A.L.D
    3,877
    617
    How are you running just the MBC? Plumbing wise that is
  21. Welly
    10,696
    127
    Charge pipe N75 nipple to inbound port on MBC. Outbound port on MBC to actuator.
  22. Andrew@A.L.D
    3,877
    617
    You just left the N75 plugged in then, Just bypassed then
  23. Welly
    10,696
    127
    Yeah, exactly that, N75 is still electrically connected to keep the ECU happy (ish).
  24. Welly
    10,696
    127
    OK, so the mapping is finished.
    Final figures are 370 BHP 331 ft/lbs.
    I haven't got the dyno prints handy, however I will try and grab them over the weekend to post. Have some interesting comparison plots of the PE1820 Vs the CR Hybrid K04.
    Have been discussing the use of a high flow inlet manifold to aid top end power. Can't help but feel that the small port inlet mani is becoming a bit of a bottleneck now. Been looking into that, so we shall see if/when I can acquire one.
    Driving on the road wise, the thing goes like a scalded cat. Really impressed with the power, and the delivery I really like. It was a bit strange at first, however the car is much more drivable now as the CR Hybrid as it was was a little over eager.
    So, that's it on this one for now - I will update with more as it becomes available.... :)
    (and the dyno prints) :thumbsup:
  25. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Well done welly and co....we need vids for a feel of the power....
    370 is certainly going to catch a few big boys out.....
  26. Welly
    10,696
    127
    Yeah, I'm sure I can facilitate that.... I need to get it MOT'd next week first, and then she'll be back out on the road again. Shibby.
  27. superkarl
    9,428
    2,398
    That is AWESOME!
    So performance wise is the extra 40 ish HP all that more savage?
    I found a good inlet mani on piston heads, I pm'd tuffty about it as he was first one I thought wanted one, wonder if its still available. It looked like a good rmr copy.
  28. Welly
    10,696
    127
    Already emailed the dude asking how much he wants for it... That link was posted earlier on in the thread somewhere I think.
    Its about funds at the moment really, or the lack of.... lol
  29. Welly
    10,696
    127
    Not so much the power, more the delivery. It's brutal. Far more brutal than the hybrid, however the power is there for less of the time... A bit of a trade off.
  30. MUSH
    MUSH MUSH Developments Ltd.
    713
    12
    Good figures there. Well done bud
  31. aragorn
    18,150
    766
    Big Turbo nommyness!
  32. Welly
    10,696
    127
  33. finesse
    finesse Active Member
    2,805
    Hats of to you Welly!
  34. jojo
    28,856
    3,516
    Good work Welly, so when is she up for sale? :laugh:
  35. finesse
    2,805
    Welly get the Mani, do be soft?
  36. Dani_B19
    9,168
    363
    Isnt that manifold slated on usa foruma for been *****! Sure ive see. It somewhere sayin the say company that produce arnt exactly a reputable company put it that way, maybe wrong though.
  37. Andrew@A.L.D
    3,877
    617
    Will you try and crack the 400 mark with this turbo
  38. <tuffty/>
    21,013
    3,776
    I think its a 39lb comp wheel so 400 seems unlikely tbh.... an inlet mani should lift the curve a bit though....
  39. <tuffty/>
    21,013
    3,776
  40. Welly
    10,696
    127
    I'd like to, dyno lottery applicable of course.... Not sure its possible realstically.
