S3 parking control module
Josh williams Dec 28, 2013
  1. Josh williams
    Josh williams Active Member
    200
    40
    Hi guys, the parking sensors stopped working on my audi s3 which has front and rear sensors
    I had the car scanned and it said it was the parking control module had a fault. I've took the parking control module out from the boot and was looking on ebay for one to replace it. Now does the number on the module have to match the replacement one?
    For example the one on mine reads 8PO 919 475 D however there is a second hand one on ebay with the number 8PO 919 475 J. If I'm correct this would be no good? I can't seem to find one on ebay with the matching part number so does this mean i need to go to audi direct and get one from them? If so how much am i looking to pay?
    Thanks in advance.
  2. Josh williams
    200
    40
    could anyone help?
  3. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Just do a google and see if the 8P0 919 475 J module is compatible with 8 sensors not 4.
    ie -
    The Audi TT Forum :: View topic - optical parking display on RNS-E 2010 coding
  4. Josh williams
    200
    40
    Just done a check on that and J seems to not work as said on the tt forum.
    Unless i can find a D second hand on ebay i may have to head to the dealers!
  5. a6_chris
    1,883
    160
  6. stupot8
    stupot8 New Member
    20
    Hi don't know if this is any use to you
    First series:
    4F0 910 283 A - 4 sensors, no graphical support
    4F0 910 283 B - ? sensors, no graphical support
    4F0 910 283 C - 8 sensors, graphical support
    4F0 910 283 D - 4 sensors, graphical support
    4F0 910 283 E - 8 sensors, graphical support, rear view camera support
    4F0 910 283 F - 4 sensors, graphical support, rear view camera support
    4F0 910 283 G - 8 sensors, graphical support, rear view camera support
    4F0 910 283 H - 8 sensors, graphical support, rear view camera support
    Second (current) series:
    8K0 919 475 AA - 8 sensors, graphical support, rear view camera support
    8K0 919 475 A - 8 sensors, graphical support
    8K0 919 475 B - 4 sensors, no graphical support
    8K0 919 475 C - 8 sensors, graphical support, rear view camera support
    8K0 919 475 D - 4 sensors, no graphical support
    8K0 919 475 E - 8 sensors, graphical support, rear view camera support
    8K0 919 475 H - 4 sensors, graphical support, rear view camera support
    8K0 919 475 R - 8 sensors, graphical support, rear view camera support
  7. a6_chris
    1,883
    160
    Those are for 4F A6's and 8K A4's ...
  8. Josh williams
    200
    40
    Thats interesting as i have 8po 919 475 d in my car now, and that list says its for 4 sensors and mine has 8!
    So if i get one of the modules from the list with 8 sensors then i should be good to go?
    Will i need to reset through vag com once the new module is fitted?
  9. Josh williams
    200
    40
    With you a6 chris, I've been told they are around £120 from the dealers.
    I may just go there and get them to sort it.
  10. a6_chris
    1,883
    160
    The modules listed above are not applicable to A3's.
  11. NHN
    29,509
    1,764
    Depending where you are, we can replace this for you & bring a module from audi over.
