  1. Stiggles
    Stiggles Top Gear!
    279
    13
    Hi again guys,
    Rear pads have worn down so needing new ones, however I have a 2.0tdi with S3 brakes all around
    Could anyone possibly give me the part numbers for the front and rear pads and discs please?
    Many thanks
  2. Lewis583
    956
    91
    Go on Autotrader.
    Find an S3.
    Take note of the reg.
    Then go on Euro Car Parts/GSF/others.
    Input the S3 reg into the "Enter your reg" box.
    Navigate to the brakes section.
    Price them up as required.
    Job jobbed.
    HTH
    Edit: and yes, Pagid/Jurid/Textar/Ferodo/Bosch/ATE are good brands to go for. If a brand is a lot cheaper than all the rest, they're likely to be **** so avoid.
  3. Stiggles
    Stiggles Top Gear!
    279
    13
    Thanks for the info, I'm actually looking part numbers specifically as I will be ordering through TPS
    The last time I ordered them there was a lengthy discussion on how there are several different sets and I'd rather have the part numbers for reference in the future.
    If anyone has them or could get them through ETKA that would be much appreciated
  4. wuta3
    wuta3 Well-Known Member
    1,124
    347
    Brakes are a PITA, im looking for rear pads and discs on ECP and there are like 3 different kinds, none of which relate to the codes in my service book. *confused*
  5. davc
    davc Well-Known Member Team Glacier Audi S3 quattro s tronic saloon
    630
    626
    93
    Here you go:
    Front Discs - 1K0 615 301 M
    Front Pads - 8J0 698 151 F
    Rear Discs - 1K0 615 601 N
    Rear Pads - 1K0 698 451 K
  6. Stiggles
    Stiggles Top Gear!
    279
    13
    Thank you very much Dav, if it's not much to ask would you know the part numbers for the rears also?
    EDIT: My mistake, misread that as front left and front right of each! Thanks again!
