*S3 Owners* What Uprated Suspension?
Rob-Quattro Dec 11, 2011
  1. Rob-Quattro
    Rob-Quattro Member
    210
    12
    As it says in the title, what uprated suspension are you S3 owners using (other than coilovers or airbags)?
    What kind of drop did you get and what handling setups are you using? Anyone done camber etc like the R32 chaps do?
  2. brough74
    brough74 Member
    423
    22
    Just H&R springs which are minus 25mm and a bit more toe in
  3. Boydie
    Boydie Boycie VCDS Map User
    3,242
    344
    H&R 25mm springs and H&R ARB's
  4. Rob-Quattro
    Rob-Quattro Member
    210
    12
    Cheers chaps but I should have made it clearer, as I don't have the S3 suspension as standard I was after shock and springs setups not just springs :keule:
  5. Scott
    Scott Well-Known Member
    1,306
    126
    Sorry to go a bit OT, but those of you with springs and standard shocks, how are you finding it? I'm thinking of going for H&R springs with a 30mm drop on the GTI when it arrives, but worried about making handling worse/bouncy ride due to shocks etc
    Rob, I know you specifically mentioned "other than coilovers" but I can definitely recommend Weitec coilovers after running them for 2 and a half years.
  6. paddy
    paddy Audi=No fault code, no idea
    5,152
    132
    Very difficult to talk about dropping the suspension and uprating in the same sentence. It might look cool in Tesco's carpark or even be better on the track if you want to spend a huge amount of money but it will never be uprating on the road.
  7. Scott
    1,306
    126
    Uprating on the road as in what sense? Handling? Or comfort/ride quality?
  8. Rob-Quattro
    Rob-Quattro Member
    210
    12
    The car handles fine now but I want it to handle the same with a slight drop. As for looking good in a car park I'm not just lowering it for show, I do drive my car how it should be used but would like it tightened for track so H&R ARBs are also being done but want it all done at the same time so I don't have to have the 4 wheel alignment done twice. Thanks Scott, I really can't be dealing with the hassle of coilovers again, plus I would lower them too much and loose the handling I want.
  9. Boydie
    3,242
    344
    Get the H&R cup kit then - springs and shocks!
  10. MartayMcFly
    MartayMcFly Booooooost Regional Rep VCDS Map User Gold Supporter
    2,749
    352
    I'm just on H&R springs for now, as a quick and very cheap short term solution to avoid new wheels making the car look raised, but the ride isn't fantastic. With standard shock constantly in slight compression you lose the first inch of bump absorption. Once the brakes and wheels go on, once the snow/cold goes away, and maybe once I've pout a deposit on a house, I'll probably look at getting Bilstein B8 shocks (a strong 8L favourite combination). I don't want the compromise of coil-overs since I don't have any need for their adjustability, might look into getting the H&R shocks to match the springs.
    And, also, definitely get the H&R ARBs, they sort the rolling and cut out a lot of understeer too.
