S3 on full lock
nig63 Jan 11, 2010
  1. nig63
    nig63 New Member
    27
    Have noticed mine sort of clunks its way around when on full lock can some one check to see if their's the same or is this not right .
  2. mitch78
    mitch78 Active Member
    2,350
    Doesn't sound right to me. Do you mean a clunking sound or what?
  3. nig63
    nig63 New Member
    27
    yep there is a clunking sound plus a kind of jump/skip .
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    126
    I'd check all wheel area bushes and CV Joint for cause.
  5. nig63
    nig63 New Member
    27
    I will get it booked in at the local dealers see what they say .
  6. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    There have been a few reported failed steering racks on S3s.
    Sounds like yours might have the same problem.
  7. nig63
    nig63 New Member
    27
    That sounds nasty . I will have a search and see what i kind find out . thanks
  8. mitch78
    2,350
    I had a similar thing, jumping wheel and clunk, it just needed a new wheel bearing, so don't jump to the conclusion that it's the steering rack.
  9. S3EDDIE
    S3EDDIE Member
    Have you just noticed it since the bad weather? Mine does it on ice but it fine normally, I had a new rack under warranty last week and mine did it earlier leaving the birds house, but there was ice and sludge on the road.
  10. nig63
    nig63 New Member
    27
    yes only since the bad weather has been around . Booked in today for them to have a look so will find out .
  11. paddy
    paddy Audi=No fault code, no idea
    5,145
    131
    My 3.2 used to do that but its stopped now. Only did it going backwards out of a parking spot ..
  12. gavsteryoung
    gavsteryoung Member
    57
    Mine also does this since the snow and ice has been around..... I think its normal.... and its only on full lock!
    MY S4 used to do a similar thing....
  13. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    No conclusion jumping here, just a constructive suggestion as the OP didnt mention anything about a problem in motion and under load.
    The main thing is that the car is under warranty.
    Valid point though.
    Paul
  14. nig63
    nig63 New Member
    27
    OK thanks for all the help the dealers said its normal so all good .
  15. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,481
    when does a dealer not say that if there isn't bellowing smoke and a dashboard full of lights!
  16. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    They reckoned my creaking rack was `dry top` mounts.
    Now Ive noticed a `knock` it is going back for more checking.
    2nd opinion might be useful. Its what I will be doing if Im told that its `normal` again.
    cheers
    Paul
  17. Phil_T
    Phil_T Revo Stage 2+ Audi S3
    240
    Mines the same & its a 59 reg
