S3 on 18" RS4'S, which profile tyres?
benh999 Jul 15, 2009
  1. benh999
    benh999 Member
    223
    just had sprayed a genuine set of TT RS4 alloys to go on my s3. Now assuming that the rim being 1" bigger than th 17" Ronals, the car on standard suspension will sit higher. my question is do I go for 40mm or 35mm profile tyres. If it helps i will be fitting AP coilovers.
    regards
    Ben
  2. MartayMcFly
    MartayMcFly Booooooost Regional Rep VCDS Map User Gold Supporter
    2,749
    352
    The 35 or 40 in the tyre size isn't mm, it's the % of the tyre's width so the difference is actually more than twice what you'd imagine (but still only ~11mm). The decision should be based on how wide the wheel/tyre is you're fitting, or what tyre you're after. I got 225/35 R18s for my RSTTs simply because I wanted F1 Assyms and they were in stock.
    I wouldn't say it's likely you'll see or feel any difference in the 1cm ride difference... there's more range between under/over inflated tyres.
    Got them from www.camskill.com, if you're interested.
  3. benh999
    benh999 Member
    223
    Yup looking at either 225 35/40 /18's
    :yes:
  4. S3Steve
    S3Steve Active Member VCDS Map User
    1,608
    17
    You want 225/40/18 for an S3 mate, to keep the rolling radius as close to standard as possible.
  5. Ian W
    Ian W Active Member
    1,058
    12
    225/40/18 is what your wanting, just had two fitted today.
  6. IIIadidasboy
    IIIadidasboy Member
    312
    The width of the wheel Vs the tyre will also play a part - if you want the "stretched" look etc.
    General rule of thumb is that the lower the profile the better the handing - but they'll be "louder" and less forgiving over bumps and pot-holes.
    It's a bit of a balancing act.
