S3 Oil Pump Change (with pics)
danger S3 Jul 26, 2012
  1. danger S3
    danger S3 Member
    362
    ok, so a while back i did a guide for removing/refitting the sump and also cleaning the pickup. this can be found S3 Sump Removal and Refit (with pics)
    so to change the oil pump i did whats in the sump removal part of the thread then started to set about the oil pump.
    to start with i removed the pickup which contained these parts (not the bolt btw). there was a bit of silicone gasket, ill put that down to using a bit too much sealant last time i refitted the sump. and the bits of plastic i think are from the broken end of the breather hoses bit that goes into the front of the engine :sorry: very glad to get them out of there
    all of the screws are 5mm allen key heads and i used a 160mm long 5mm allen key on a 3/8" socket. just like this one Hex Bit 5mm x 160mm Ball End 3/8"D Laser 2870 | eBay Laser part number: 2870. They are also hex heads so a 10mm socket on the oil pump bolts as if they are a little tight they can round using a 5mm allen key (thanks for the suggestion of the 10mm socket <tuffty/>)
    Then i removed the baffle which is held on by one screw (screw also helps hold the pump on) there are 3 screws holding the pump on.
    once the baffles off u get a good look up into the engine
    and also you can see the underside of the engine and the old oil pump without pickup
    there are another 2 screws and once they are undone you can get into removing it, below you can see there is a spring loaded tensioner. i removed it by having the oil pump hanging down and holding the tensioner back and slipping it off the sprocket. ElsaWin says you should remove the sprocket to get it off but i thought this was easier.
    if you do choose to take the sprocket off the torque for re attaching it is 22Nm.
    here are a couple of pics of the old oil pump next to the new one, quite a difference in colour
    now for fitting the new oil pump, i noticed that the old oil pump had left one of its plastic dowels in the block so i removed that and used the 2 that came already in the new pump.
    I also took some new oil and put it through the new oil pump and make sure it had been run through and spinned lots to get it all lubed then filled it and fitted it
    installing is just a reverse of the removal really. wee bit fiddly to get it back on the chain but it wasn't too bad.
    here is a pic of the new oil pump in but not torqued up yet. also the baffle isn't on yet, it needs to be on before the baffle screws tightened obviously :icon_thumright:
    the torque settings to put the oil pump onto the block is 16Nm
    the last pic here is of the oil pump fully fitted and torqued up with the new pickup attached.
    after that i just cleaned up the mating surfaces with some alcohol and re attached the sump in the previous guide S3 Sump Removal and Refit (with pics)
    to recap the torque settings:
    Chain sprocket to oil pump shaft - 22Nm
    Oil pump to cylinder block - 16Nm
    tools needed:
    Hex Bit 5mm x 160mm Ball End 3/8"D Laser 2870 | eBay - Laser part number: 2870
    That's all folk, if there is anything I've forgotten (there probably will be) please feel free to jump in :beerchug:
    oh and the last point, got for a drive :racer:
    SteveBAM and JUS3IN like this.
  2. superkarl
    superkarl MAN OF STEEL
    9,371
    2,368
    excellent guide! well done mate.
  3. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    great help mate as ill be doining mine soon
  4. <tuffty/>
    20,847
    3,687
    I would use a 10mm socket on the oil pump bolts personally as if they are a little tight they can round using a 5mm allen key..
    I normally remove the sprocket but I do use an impact gun to wind it off then torque it back on with a torque wrench..
  5. v5 tt
    v5 tt Member
    87
    Excellent write up :beerchug:
  6. slowcoach3
    slowcoach3 Active Member
    822
    103
    43
    Always like your write-ups, they're so easy to follow.....Don't suppose you fancy doing one for removal/refit of the head do you????!!!!
    JLKitching likes this.
  7. danger S3
    danger S3 Member
    362
    Cheers guys, glad you like it.
    Tuffty i edited my post to add in your 10mm socket suggestion :thumbsup:
    slowcoach3 i hope i never have todo a guide for the head but if i do i will sort it. just like i hope i never have to do anything with my turbo. but I'm ready to man up if i have to :weight_lift2:
  8. s3gazz
    1,376
    99
    well as iv started my build i was at this stage of removing the oil pump and undid it all as said above but could not get the chain off so might have to take the tensioner off or the oil pump cog itself
  9. <tuffty/>
    20,847
    3,687
    Remove the cog mate... I normally use an impact gun to remove it but as long as you can lock or prevent the crank from turning while you so it then it will come undone
  10. s3gazz
    1,376
    99
    Thanks mate ye I noticed that as I turned the crank to get piston 1 an 4 top dead flush then went to undo it moved so need to some how stop it from moving too fidly taking chain off ha
  11. vfr800
    vfr800 Active Member Team Dolphin Grey Audi S3 quattro Audi A6
    773
    57
    Nice write up.
    Why did you change the oil pump? Had it failed or were you doing preventative maintenance?
    Is it the sort of thing everyone should think about changing (on high mileage engines) or only if they have a problem?
    Liam
  12. superkarl
    9,371
    2,368
    if you ever have the sump off for any reason, i see that as a perfect excuse to fit a new one. preventative maintenence
  13. danger S3
    danger S3 Member
    362
    Thanks.
    i changed it as a preventative measure, basically my thinking was if the oil pickups been partially blocked for dunno how many miles then the oil pump wouldn't have had the same lubrication it would like so it might be getting worn.
    so i changed it. looking at the old one that came out it actually seemed in reasonable nick but you know its just a piece of mind thing really. I'm still glad i did it.
    Ali
  14. vfr800
    773
    57
    I finally changed my pickup and oil pump yesterday. It was a heck of a messy job, loads of oil kept dripping out of the engine onto me.
    My pickup pipe was hardly blocked at all. Oh well, i know its all good now and should all be good for another 100k+.
    To change the pump I pushed the tensioner back, it was easy enough.
    I'm hoping I put the sealant on well enough that it stays all sealed.
    Thanks again for the write up. Super helpful.
    Liam
  15. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    Well done Liam, good to have that peace of mind though. My pick-up was also pretty clean when I dropped my sump last year, but I'm still glad I checked it.
  16. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    great write up mate, those 2 sump bolts in the gearbox are a right sod! my pickup was full of crud no wonder i had a rattly top end, bits off instant gasket and nearly all the holes blocked!
  17. slklite
    slklite New Member
    Hello guys, is it possible to reup the pictures ? They seem to have been deleted in the host ...
    Thank you guys ;)
  18. danger S3
    danger S3 Member
    362
    That's strange, i don't know why they're not showing up.
    If you right click on them and copy image link then paste the copied link into the address bar at the top they seem to load.
    can anyone else see them?
  19. westcoast a3
    westcoast a3 Active Member
    317
    37
    no showing for me either bud :/
  20. Amex
    Amex New Member
    21
    Upload to other host.
  21. danger S3
    danger S3 Member
    362
    Hope these worka but better, let me know if there are any more issues.
    Stuff stuck in the old pickup:
    Plastic Baffle:
    Piston and bearings:
    Old pump without pickup:
    Chain tensioner:
    Old and new pumps:
    Old and new pumps:
    New pump fitted:
    New pump fitted:
    New pump and pickup fitted:
    SamHendry likes this.
  22. slklite
    slklite New Member
    Thnak you, for this !!!
  23. Erikn89nl
    Erikn89nl Well-Known Member
    686
    252
    I hope that bolt just photobombed, and wasnt actually stuck in the pickup pipe :p good work, and good pics too :)
  24. IanPG
    IanPG Well-Known Member Team Nogaro Blue Silver Supporter Audi S3
    1,019
    374
    How is the tensioner slackened to be able to remove the pump???
  25. badger5
    9,374
    1,916
    you just remove the oil pumps drive gear
  26. IanPG
    1,019
    374
    Drive gear = the big toothed one?
    Thought there was a way where you didn't need to do this...
  27. badger5
    9,374
    1,916
    is a t40 torx too difficult for you? :p
  28. IanPG
    1,019
    374
    At this point my 1/4" only goes up to t30 :sorrow:
    Haha
    Didn't realise it was simple as that
  29. <tuffty/>
    20,847
    3,687
    The tensioner is just sprung loaded.. you can hold it away from the chain and maneuver the pump out but it is awkward and doesn't come out easily...
    As Bill said though you can use a t40 and an impact gun preferably...
    IanPG likes this.
