S3 Oil Leak On Startup From Oil Cooler
Tooks Mar 31, 2013
  1. Tooks
    Tooks Active Member
    753
    30
    Hi guys.
    Typically, and when all the car parts shops are shut today, my S3 has developed a startup oil leak that appears to be coming from the oil cooler where it meets the engine mount.
    I understand this is a common problem, and the o ring part is cheap. The problem is, where to find one today or tomorrow?!
    I have a couple of new oil filters, I have read that an oil filter seal ring is the exact same thing, and will do the job just as well as the OEM part? Certainly a few pics of the aftermarket parts look just like the oil filter ring...
    Any thoughts/experience?
    Ta!
  2. <tuffty/>
    21,696
    4,123
    The seal I think you mean is different to the oil filter one... the proper one is as you say and o-ring with two locating tabs... looks like this
    Not sure where you would find one though... halfrauds won't have anything like that so your only bet is a decent motor factors which is open on a bank holiday... again unlikely...
  3. Tooks
    Tooks Active Member
    753
    30
    Yep, that's the one.
    I read that the tabs are unimportant, although I wonder why they're there! Probably to aid with installation or something.
    Im thinking that if the oil filter o ring is the same size, then it should work the same?
  4. <tuffty/>
    21,696
    4,123
    Arguably... all things considered its worth a punt....
    The tabs are to locate the o-ring so when you fit it it is in the right place to seal properly... without them it stands a chance of moving and not sealing correctly resulting in a leak... The tabs are important for this reason (to make it essentially idiot proof) but if you are aware and are careful then it could work...
  5. Tooks
    Tooks Active Member
    753
    30
    Thanks tuffty, I think I'm going to give it a go.
    The existing one has clearly failed, so even if I get it fixed whilst I await the original part, it's better than it leaking. I'm concerned it will let go completely.
    Worse case, I can always stop and try and get a part mid week if this doesn't look like it will work, but would rather not have to take a day off sorting it.
    I will let you know how I get on!
