S3 now on H&R lowering springs
nervus Jun 11, 2014
  1. nervus
    nervus Well-Known Member
    1,370
    121
    I fitted my H&R lowering springs today (supplied by GNJ motorsprt who provided an exceptional service - thanks again Graeme!!!)
    It took me approx. 3 hrs as im an amateur and needed to go for a couple of specialist tools (14mm spline drive bit and a hub/ strut spreader totalling £20).
    Anyhow, i was sceptical 20mm wouldnt be enough of a drop but it looks absolutely spot on!!! Low enough but not chavvy low! The springs are marginally stiffer but the ride when just cruising is very similar to the stock springs. Only when pushing on do you notice the springs get stiffer under hard cornering load which massively improves the dynamics of the chassis.
    Understeer is dramatically reduced and the car corners more flat with body roll vertually eliminated. Also, the springs can be fitted without tampering with any of the the adjustable geometry components so struts etc are a straight swap out and re-locate in the same position.
    The additional 20mm drop must have changed the geometry settings but im confident it tracks true and straight. ill get it checked at next oppotunity. Well impressed though and will be getting some new MTM Bimoto wheels and spacers soon!
    very very happy!
    J6YAK likes this.
  2. J6YAK
    J6YAK Team Dark Red Mica
    502
    393
    Good lad best get some pics up soon then.
    I'm on the verge of ordering some myself.
    RYuill likes this.
  3. nervus
    1,370
    121
    You wont regret them J6YAK stance is perfect! I'm getting the chrome windows and grill replaced with black trim now so will post pics when complete :)
    BTW - if anyone wants any guidance on fitting themselves just PM me!
  4. Don76
    Don76 Well-Known Member
    598
    322
    How you going about the removal of the chrome fella?
  5. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    Sounds awesome!
  6. Don76
    598
    322
    Any pics yet fella?
  7. Bain0
    Bain0 Active Member
    51
    108
    33
    This thread is worthless without pics..
    J6YAK, mls, S3 TRS and 2 others like this.
  8. RobH_S3
    RobH_S3 Active Member
    440
    208
    43
    I just want VWracing to huury up and release their springs they've been in development for months on their Golf R safety car so they should be set up perfectly.
    Cant imagine H&R putting as much effort into the R&D for this car. Something to consider for all those wanting to lower with improved handling ;)
  9. Fiddie
    Fiddie Active Member
    255
    127
    43
    What about the pics??
  10. ahyeah
    ahyeah New Member
    Pics plz
  11. tcardio
    tcardio Well-Known Member
    1,009
    298
    care meter
    don't care.....x...........................................................................care without pics
  12. visionthing
    visionthing Active Member VCDS Map User
    210
    91
    Had H&R lowering springs installed today in my S3....
    Before
    After
    Ride quality imo is as good as before and less body roll when cornering. :thumbsup:
    Fiddie, nervus and RYuill like this.
  13. nervus
    1,370
    121
    push it hard, less understeer, backend actually goes first :o.k:
  14. Fiddie
    255
    127
    43
    Do you have Magnetic Ride? I heard with Magnetic Ride is about 1' up than normal shocks.
  15. visionthing
    210
    91
  16. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    Come on get some pics up - the Chrome window surrounds are the one thing I don't like about the new S3
  17. nervus
    1,370
    121
    LOL - Car has been back and forward to dealers as MMI is fecked amd keeps needing resetting, now needs a new unit and they've had it for 3 days now! I'll get some up as soon as its back! Will probably be Wednesday as im in Ireland Monday/ Tuesday!
  18. S3 TRS
    S3 TRS Active Member
    497
    226
    43
