S3 No boost
Jacko4130 Oct 21, 2010
  1. Jacko4130
    Jacko4130 Goodie Gum Drops
    848
    Hi Guys
    Had my S3 remapped 3 months ago, since then its been nothing but trouble, have had to replace turbo intake pipe, breather hose left of inlet manifold, breather hoses underside of inlet hose, mass air flow meter. Finally got it running at full boost last night after the inlet breather hoses got replaced.
    Can to the car this morning and have no boost at all, turbo is not spooling, it was fine when it got parked up last night. Had a quick look while on route to work this morning but cant see any hoses leaking. Scanned the car and its come up with a DV fault.
    Question, If the DV was buggered would that stop it boostng?
    How do i tell if the N75 valve is working?
    Car is a 225 BAM
    Cheers Jacko
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    get it scanned mate...could be anything
  3. Jacko4130
    848
    Its not putting up any codes apart from DV, First thing i did was scan it with a code reader. Can DV Failure cause no boost?
  4. Sandip
    2,438
    90
    Remove the T.I.P and just check if the turbo is turning free
  5. Jacko4130
    848
    Turbo spins fine, has a little play in shaft but nothing major, would think its a vac hose or DV problem. So can anyone tell me if DV is dead would i suffer from no boost?
    cheers
  6. Lee172
    Lee172 GT3071
    430
    Why dont you take your dv off and check it. If you push the piston up and put your finger over the vacuum the piston should stay up, when you let go it should go down. This is what some one on here told me the other day. check thread 'Why forge 007p'. I checked mine and it when down half way so dont know if i have a leak or not?
  7. Jacko4130
    848
    All sorted now, Turned out nothing to do with the DV.
  8. s3dave
    10,110
    736
    ?? come on then....lol
  9. JamJay
    JamJay Member
    188
    Lol I love threads like this. I have an issue with my car and Google throws up all of these threads but no-one concludes lol.
    antwon likes this.
  10. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,821
    105
    Yes . lovely, use the forum to search for threads that help... but when you find it to be something not covered....
    Leave us all hanging
  11. antwon
    antwon New Member
    i got the same problem.. Got in my car earlier n no boost atall. switched my engine off. n back on now its fine :s??. Any ideas??
  12. Westy
    Westy Well-Known Member
    17,440
    1,096
    Your car has thrown a fault that's triggured soft limp mode, this puts the car down to 6psi of boost max. By turning off the car and on again it will clear the limp mode until the fault gets flagged again.
    It will be difficult to determine what the problem is unless you get your car scanned with VCDS.
  13. antwon
    antwon New Member
    Ok thanx for that w3sty! So were do i get it scanned?? Is it just a diagnostic?? :s
  14. antwon
    antwon New Member
    Oh and i was told it could be the air flow metre... Is that pos?
  15. Westy
    17,440
    1,096
  16. antwon
    antwon New Member
    LOL!! ok thanx for your help mate. :)
