S3 mtm conversion help hole in part of downpipe
Goubo1 Oct 19, 2012
  1. Goubo1
    Goubo1 Well-Known Member
    949
    281
    Hi guys was wondering if anyone knows if it would be possible to patch this up if so how ?,or do I need a brand new part the pipe,this pipe is attached to the external waste gate I believe
  2. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Looks like a bad flexi joint. Suggest you remove the dp, cut the **** flexi joint out and get a proper one welded in. You can buy them off the bay or I'm sure good exhaust shops sell them
  3. Goubo1
    949
    281
    Cheers for the reply mate,do you know what type of flexi joint I need in terms of size etc and I will order 1
  4. beachbuggy
    1,931
    201
    No idea what size your dp is! I guess maybe 2.5 or 3" but until you remove it you won't be sure or could measure it situ . If you look on eBay a 3" flexi exhaust joint is about £25.
  5. Goubo1
    949
    281
    sound mate cheers,do you think I should buy new gaskets for the downpipe or think I could get away with reusing them ? As I don't really know what down pipe it is
  6. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Pm'd but for future reference of anyone else the MTM kit uses rs2/s2 gaskets, wastegate and very simular turbo ;)
