S3 Modified brake pads, from dealer!!
S3RYE Aug 20, 2009
  1. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    Hi,
    Basically my brakes were sqeaking really bad, not when coming to a stop just constant everytime i broke just constant untill i come to a stop.. (even from 70mph)
    so i went on and on at Audi and basically the service advisor said to me that Audi have had so many complaints about the S3 brakes (and any other Audi model using these caliper/disc/pad combination) that they have designed a new pad that doesnt squeak as much. they have agreed to replace my pads with the new modified ones F.O.C under warranty which is a result as ive done 9000 miles on mine.
    so anyone with the same problem go to dealers n hassle!!
  2. edition
    edition Active Member
    1,426
    Hmmmm thats good!!!
    Pity mines done 45k don't think they will be as pleased to change mine!
  3. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,405
    546
    darn it lol i have just bought pads and my front left it squealing!
  4. dc240969
    dc240969 Member VCDS Map User
    925
    had mine change 2 weeks ago under warranty
  5. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    64
    Someone once said the squealing is caused by the small lip on the edge of the disc. They had them skimmed and the squealing went.
    What is the mod they do? Bigger pads??
  6. Spin140
    Spin140 Well-Known Member
    2,196
    186
    Mine squeal too, I like it, I have a thing for mice :)
  7. Ash B
    Ash B Well-Known Member
    5,831
    84
    :lmfao:
  8. Jamiekip
    Jamiekip Member
    717
    Just emailed my dealer to see what the change is.
    Every time they have my car I ask them to get rid of the squeak and they cover them in copper grease... works for a while, but if there is a proper fix I'm going to try and get it.
  9. dc240969
    925
    lm not sure about mod, chamfer maybe. l was told its due to the properties of the pad. well talked about on here.
  10. Staz
    6,206
    64
  11. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    Mine squeal quite a bit too, I think I may have to mention it next time mine goes in.
    I think I've got an issue with the windows and my fan motor seems to squeal on startup from cold.
  12. Spin140
    2,196
    186
    Audi Build quality again :(
  13. Staz
    6,206
    64
    I think the build quality is great! It's just they have issues the same as anyone else.
    In the 2 Audis I have owned I have had 2 problems. The windows one in this car that was sorted by the dealer and squealing brakes. Hardly something to complain about IMO.
  14. lsw s3
    lsw s3 Member
    40
    whats the window thing ???? :ermm: is it something thats still a issue with the s3 ??
    lsw s3
  15. Jamiekip
    Jamiekip Member
    717
    My friendly dealer contact is investigating this for me and will let me know what instruction they have on replacing brakes..... watch this space.
  16. S3RYE
    3,448
    70
    basically the compund of the oem pads seem to attract brake dust and actually set the dust into the surface.. causing really bad squeaking.. short term fixes are as jamiekip mentioned are covering in copper grease or roughing up pads again (to remove all brake dust) but these are purely short terms.. i had both done several times. The new compound apparently is no weaker in terms of braking power but doesnt attract and hold brake dust..
    hope this helps.. im getting them fitted next saturday so ill let you all no how they are the week after! :icon_thumright:
