S3 misfire when cold
rsstu
hi there
I recently purchased an 02 S3 with 80k
when I viewed it at a garage and then collected it, they had ran it up to temperature which I now believe to be due to a mis fire when cold
it goes once at temperature, I am suspecting coil packs??
I had a full service done on her yesterday and the following fault codes came to light 16684, 16688, 16686, 16687
Also, when really thrashing it, it crunches going in to third gear, any ideas??
thanks for your attention to this and advice
stu
http://wiki.ross-tech.com/wiki/index.php/16684/P0300/000768#Special_Notes Full service including plugs?
I would;
- change the coilpacks & check coil pack wiring
16684/P0300/000768 - Random/Multiple Cylinder Misfire Detected
Possible Causes
  • Air Intake System leaking
  • Fuel Supply faulty
  • Injector(s) faulty
  • Ignition Cable(s) and/or Spark Plug(s) faulty
  • Ignition Coil(s) faulty
  • Exhaust Gas Recirculation (EGR) Valve (N18) stuck/open
  • Camshaft Position Sensor (G40) faulty
Possible Solutions
  • Check Misfire Recognition
  • Check Air Intake System
  • Check Fuel Supply
  • Check Injector(s) and Injector Sealing
  • Check Ignition Cable(s) and Spark Plug(s)
  • Check Ignition Coil(s)
  • Check Exhaust Gas Recirculation (EGR) Valve (N18)
  • Check Camshaft Position Sensor (G40)
brilliant thanks mate, change all coils packs??
id take it back and let them fix it
coil pacls will missfire hot or cold
Crunching of the gearbox into 3rd is very common, most noticeable changing at high revs. An uprated dogbone mount(£20 from powerflex) will reduce engine movement and make gearchanges more positive. Trade off is more vibrations into through the steering column from the engine.
