S3 MFSW to FBMFSW - Weird Problem?!
realstig May 9, 2013
  1. realstig
    realstig Member
    33
    Hi All,
    I have been a 'viewer' and read many threads here over the years. I really hope somebody can help...
    I have a 56/2007 Audi S3 that had the normal multi function steering wheel. I purchased a FBMFSW (including the airbag) from a 2010 S3, everything fitted in fine and there are no warning lights on the instrument cluster. However, the buttons on the steering wheel do not light up nor do they work. :ermm:
    I've had a look at the original airbag and wiring loom that came out of the car and it is 8J0 971 589 Q.
    I thought it was supposed to be a straight forward fit? I don't know the part number for the wiring loom that came with the FBMFSW as that is now in the car but I presume it would be the correct one?
    Can anybody help? (I have cruise control too, specc'd from the factory)
    Thanks in advance.
  2. realstig
    realstig Member
    33
    Could it be the fuse? As it looks like I'm getting no power at all.
    I might just put the original steering wheel back in and make sure everything still works...
  3. fangio
    fangio Well-Known Member
    1,439
    163
    Coding maybe?
  4. realstig
    realstig Member
    33
    My car already had a MFSW, so it shouldn't need coding?
    Also, I would still expect power and lights to the buttons if it was a coding issue.
  5. fangio
    1,439
    163
    Had to code mine when I changed it.:uhm:
  6. Lewbo
    Lewbo Well-Known Member
    1,265
    103
    If you already had MFSW that worked correctly then I won't need coding as its already done and I have done this myself in the past. On my last a3 when I changed to FBMFSW I plug for the MF wast clipped in properly and they didn't light up or work so maybe give that a try that's only reason i could think of.
  7. realstig
    realstig Member
    33
    Ok I'm going to take it apart now and will take a look again - thanks!
  8. realstig
    realstig Member
    33
    Just thought I would this thread, a3_sline_tdi was spot on, many thanks!
    I took the wheel apart, made sure everything was connected tightly and voila!
  9. Lewbo
    1,265
    103
    No problem mate glad you got it sorted.
    realstig likes this.
  10. realstig
    realstig Member
    33
    The other thing I've noticed is the steering wheel isn't straight any more, on a straight road I have to turn it to the left. I made sure I put it back on exactly straight and before I changed the SW, it was exactly straight i.e. tracking wasn't required.
  11. Ash187
    7,444
    704
    when you fitted it back on did you see where the little notch is on the slip ring that shows you the centre of the steering angle?
    you may need to do a steering angle reset in vcds if not
  12. realstig
    realstig Member
    33
    Yeah I made sure the little notch and the middle of the steering wheel lined up perfectly. Will a steering angle reset physically alter the alignment of the steering wheel?
    Is there anybody in the Manchester / North Manchester area who has vcds?
  13. Ash187
    7,444
    704
    The numpties at ATS Camden (London) tried to track my wheels after i first fitted the 19s and said they couldnt do it. I drove into the place with the steering wheel perfectly straight and they returned it back with it at a 45 degree to the left. took it to Elite a couple days later who straightened up the tracking but the car still thought that it needed the steering wheel to be 45 degrees to the left in order to go straight... did a steering angle reset there and then and it straightened up the wheel perfectly.
  14. realstig
    realstig Member
    33
    That's interesting to say the least! Is it fairly straight forward to do the reset?
  15. Ash187
    7,444
    704
  16. realstig
    realstig Member
    33
    Wow...I don't think I'm going to be able to do that. Looks like I need to find somebody who can do it for me.
    Any takers? I'll contribute towards the service
  17. Mikemc
    Mikemc Scooby Slayer VCDS Map User
    1,024
    37
    I'm in Warrington if you don't find anybody closer
  18. realstig
    realstig Member
    33
    Thanks, I'm going to get the wheel alignment done this week. If that doesn't fix it, i'll be in touch
  19. Mikemc
    1,024
    37
    Cool, I'm off work all this week with a knee injury so pretty much anytime is good
  20. realstig
    realstig Member
    33
    Ok, its booked in for Friday afternoon. Will keep you posted.
