s3 manifold to turbo bolts
tony696 Oct 26, 2010
  1. tony696
    tony696 Member
    165
    Hi all where the best please to get the manifold to turbo bolts the 3 of them
  2. Ian W
    Ian W Active Member
    1,058
    12
    Audi I reckon, about a fiver each though iirc
  3. Andrew@A.L.D
    3,879
    617
    A engineer or a nut and bolt specialist
    Look on ebay for engineering studs, just as good and far less to buy
    I paid £1 each for mine
  4. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    I'd stick with OEM personally, despite the cost. They need to be of a certain hardness, due to the heat the deal with.
    I had some made out of stainless steel quite cheap, but went with OEM in the end.
  5. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    I when for OEM once. They were about £16 but they have to withstand a lot of heat and probably a different grade of steel compared to most normal bolts.
    Nathan
  6. Andrew@A.L.D
    3,879
    617
    You can get high temp, high tensile ones. I fitted some of the same studs to a mates supra and there still doing fine.
  7. Welly
    10,696
    130
    Fair shout dude, if they're still going them all is good. Any links for future reference?
  8. Andrew@A.L.D
    3,879
    617
    I have them on mine and will still use them when i go BT as i totally trust them. My mates Supra has been on the dyno with the manifold and studs glowing cherry red.
    I get them form a local place just up the road from where i live
    Bolt & Nut Supplies Ltd, Civils Products, Drainage Merchants
    They do not do delivery but everyone will have a place like this near to them, take a stud into the shop and they will match it if you tell them there is a lot of heat passing through them.
    Pick up the yellow pages and have a look for a place near to yourself's.
  9. Welly
    10,696
    130
    I know of a place near me, called GR Fasteners. Will pop in and ask them. :thumbsup:
  10. Andrew@A.L.D
    3,879
    617
  11. Andrew@A.L.D
    3,879
    617
