s3 intercooler
webby1001 Apr 5, 2010
  1. webby1001
    webby1001 Member
    51
  2. devonmikeyboy
    devonmikeyboy As far from JBS as possible !
    1,245
    To what car with what mods ?
  3. dc240969
    dc240969 Member VCDS Map User
    925
    [FONT=Arial, Helvetica, sans-serif]Not permitted to use in the area of the Highway Code! Says the small print?[/FONT]
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    for starters i wouldnt buy an unbranded one, youve no idea what it is, what its made from and what it operates at
  5. devonmikeyboy
    1,245
    Thats just the usual cover their ass statement for different laws in different countries.
  6. S3Alex
    10,835
    4,830
    Firstly,it's worth taking a look at the size of this thing,which is about 1/3 of the size of the OEM S3 intercooler,and whilst it looks well made enough,I can't see any benefit over something like Forge's add on Twintercooler,and I'm sure most people know what I think of add-ons.
    Next,as devonmikeyboy rightly says.....what car,what previous mods and what do you intend doing next?
    Surely it's best to not only have a clear idea of what you want to do with whatever car it is,but also to look for the right parts for the job first.
  7. webby1001
    webby1001 Member
    51
    im looking at getting 350 bhp. got revo map and dv etc. so ino next kind of think is fmic and hpfp. i see your runing 365 bhp. any think else you got? and has your clutch gone? or have you a uprated one?
  8. S3Alex
    10,835
    4,830
    What car are you driving?
    If it's an S3 then you don't need an aftermarket intercooler until you get above 400bhp,and for that you are going to need low compression pistons,stronger rods and a few other things incl a bigger turbo.
    Mine has been on the rolling road lottery and turns out about 360+bhp...it feels about right in comparison with other cars I've had with similar or higher outputs.
    If you're using a standard clutch,that will chuck in the towel fairly rapidly over 310bhp/300+lbs,and its the torque that kills it.
    Like many others here,I have the Sachs clutch.
    I seriously wouldn't be too keen on the FMIC unless you go above 400bhp,and I would still put my money on a single large uprated intercooler,than an add-on piggy-backed onto the existing one....if most of us get to 360bhp+ without it,you don't need it,as this is about the ragged edge of what the stock turbo is capable of flowing in gas terms.
  9. webby1001
    webby1001 Member
    51
    yer its an s3 8p. so a hpfp would really take it past 350 bhp? what mods you running altogther?
  10. S3Alex
    10,835
    4,830
    OK....my list is much the same as everyone else's here.
    Sachs clutch.
    Milltek exhaust
    CAI(you can choose from Forge,ITG,EVOMS etc etc)
    HPFP
    Revo Stage 2+
    That's about it.....mine makes over 360bhp on the lottery,and as I've said it does feel about right(I had a 440bhp Sierra and a 360bhp Escort previously...both were dyno'd and the S3 feels about right on power).
    You need the HPFP to run Stage 2+,as without it,you get a large dip in midrange torque,and the HPFP will jhelp smooth that out as well as delivering sufficient flow for higher power levels.
    Once you get about that, unless you're really interested in the minimal difference between 360-370bhp,and possibly 380bhp,you don't need an add-on intercooler.
    To get over 400bhp you do need a bigger turbo,RS4 injectors,a remap,low compression pistons and tougher rods,and possibly new head bolts.
    You may also need to consider cooling upgrades for oil and water,and you will definitely need better brakes.
    That's easily several thousand bucks,and it isn't worth cutting corners with as you WILL have trouble soon enough.
    Do any modding in stages unless you can afford the whloe thing in one go,and I would start with a simple remap and exhaust.
