S3 Intake need help!!
gr1zly Dec 23, 2007
  1. gr1zly
    gr1zly Member
    207
    I want to upgreat my intake. But I can't decide what to do, because nobody can't tell my which option is the best.
    One option is CAI, but I am not sure that is safe option because water can go inside the engine.
    Other option is this
    Neuspeed P-FLO™ Induction Kit with Neuspeed Hi-Flow Intercooler Pipe Coversion 2.0T
    http://awesome-gti.co.uk/audi a38p/engine.html
    Maybe some of you have already done something with it.
  2. Boydie
    Boydie Guest
    mate - you are missing something in the links as they are not working :(
  3. gr1zly
    gr1zly Member
    207
    I've change them to awesome-gti link
  4. SSS3
    SSS3 Member
    39
    hmmmm ....
    I would be 100% sure that the intake you get has all the plumb-back fittings ie. recirc valves fitting.
    I put on a custom intake based on the Forge 2.0T GTI intake.
    Gained around 25wkw, and it now gives a "squirrel under the bonnet" chirp when you snapchange gears ;)
    goodluck with that ;)
  5. gr1zly
    gr1zly Member
    207
  6. fraud
    fraud jamo s3
    96
    the cai,s look nice but i,ve just gone for the green cotton air filter cheaper and there won,t be much difference in performance i don,t think
  7. gr1zly
    gr1zly Member
    207
    I am looking back to find good intake for my new S3 sportback :)
    I thought that only air sport filter or Carbonio will be enought but, my mechanics said that it would be better to instal Forge CAI or EVOMS V-flow, because air filter in S3 is behind engine is rather hot then cold...
    I am a bit confiused what to do... ?
  8. phantom
    phantom On Boost
    1,750
    I wouldn't spend the £150 on a Carbonio , either spend £250 on a forge , EVOMS , Dilbas , or £30 on a decent panel filter.
    p
  9. gr1zly
    gr1zly Member
    207
    I think that carbonio is the best option but my firend has got it i GTI MK5 and he is not very happy of it...
  10. jonnyc
    jonnyc Member
    858
    If you would like something pretty to look at under your bonnet then go for the Carbonio, other than that it doesn't really have anything else going for it over buying a £25 panel filter..
    All of the full intake systems as listed earlier in the thread will add some performance.
    I run the EVOMS intake with the MAF heat shield, and filter heat shield.. I have also covered the intake above and around the turbo area in heat reflecting tape and fitted a cold air feed from the LHS fog light grille directly to the filter itself..
    The intake is now running super cool and the gains over the OE intake/engine cover feel huge..
    Heres a pic..
    Evoms intake - £275
    MAF heatshield - £25
    Heat reflecting tape (depending on how much you buy) - £40
    Cold air feed with venturi - £40
    Well worth it IMO..
    Jonny
  11. gr1zly
    gr1zly Member
    207
    Can you make some more pictures, from the end of the intake?
    Did you buy everythink at evoms USA??
  12. DeckedS3
    DeckedS3 Well-Known Member
    882
    304
    What does the Carbono look like then?
  13. gr1zly
    gr1zly Member
    207
  14. jonnyc
    jonnyc Member
    858
    Hey
    The intake is a standard v2 EVOMS intake for the 2.0T FSI cars with remotely located DV (hence the DV recirculation pipe)
    I purchased all of the parts from Regal Autosport here in the UK who are the official Evolution Motorsports importers for the UK
    Jonny
  15. Fast,not furious
    Fast,not furious Dealing with an OCD
    416
    Looks like i checked out this thread just in time!
    I was considering the Carbonio,it sure looks pretty,but further investigation leads me to believe it's just a glorified intake:crying:
    Now i'm leaning towards Forge or the Evoms you mentioned....just a shame i moved away from Southampton....Regal were 15 mins away! Doh!!:(
  16. Fast,not furious
    416
    ....and now even more confused,just checked out Regals website...and they offer the Dbilas Flowmaster....to their knowledge,the first dedicated intake for the large turbo (K04) 2.0 TFSI 8P £325.01 inc vat....similar to the Evoms,but without the extra cold air intake.
    Any thoughts??
  17. gr1zly
    gr1zly Member
    207
    I think EVoms looks a bit better then Forge...
  18. jonnyc
    jonnyc Member
    858
    Dbilas is also a very good intake..
    The reason I went for the Evoms over the Dbilas is that the Dbilas runs an enclosed air box and therefore will be quieter than the Evoms kit and I wanted some noise! ha..
    Either way your going to end up with a very good intake system which offer very similar gains in performance, I would say its more down to the level of noise that you would like..
    And when I say noise its not like a jet engine, just an enhanced version of the OEM intake sound..
    Jonny
  19. Fast,not furious
    416
    Thanks for that,i'll do some more research....love your S3 in white:rockwoot:,just wish i had the balls to go for one!!
  20. gr1zly
    gr1zly Member
    207
    If I decide that i wuoold buy dbilas, do you think I need heatshield also??
  21. jonnyc
    jonnyc Member
    858
    I would say that its a must but for sure it helps reduce the heat soak from the turbo into the intake pipe.. and its only £25..
    Jonny
  22. Scorpius
    Scorpius The S Factor
    82
    Hey guys
    Most of the S3 guys down here in South Africa have opted for the Forge intake. Only one available locally for the S3's here. Typically seeing around 15-20wkW increases with the intake on. I'll be fitting one soon as well but still weighing my options. We have a distributor for EVOMS but their current intake is meant to fit the GTI and not the S3. Quite interesting to see that your UK distributor has the DV relocation parts that have made it fit to the S3.
    In any case, I had contacted EVOMS about this and they stated they are currently busy with an intake designed specifically for the S3 and it should be released in July. May be interested to check it out then.
    Jonnyc, do you have a link to the part that feeds the cold air directly from the fog grille to the filter. I have noticed that the Forge intake sits lower down to take advantage of that whereas the EVOMS intake is higher up in the engine bay. Concerned me that it may not be getting as much cold air as the Forge one and didnt know of a solution like on yours. Also, what were the power and torque gains after you fitted the intake?
    Thanks!
  23. jonnyc
    jonnyc Member
    858
    My EVOMS intake was actually the development piece produced by Regal Autosport to aid EVOMS in producing a solution for the S3/ED30/Cupra 2.0T FSI engine..
    Yes the forge intake sits lower down in the front bumper, I bought different pieces and manufactured my own cold air feed using a 100MM venturi duct which sits in the front grille and routed 76MM ducting directly to the filter
    Works really well and the car certainly feels quicker after fitting all of the 'cooling' mods.. Next thing for me to do really would be a Forge twintercooler, not sure if anyone has done this yet on an S3?
    Jonny
  24. gr1zly
    gr1zly Member
    207
    I am thinking about it but first want see some test of it...
    I want to buy as many stuf for my new S3 sportback as a can.... :)
  25. phantom
    phantom On Boost
    1,750
    I thought you would of gone down the fuel pump route Jonny?
    Have you seen the curve on the plots of the cars ( ED30 and Cupras ) that have had it?
    There nearly flat.
    p
  26. Scorpius
    82
    Thanks jonnyc!
    Dont know any S3 with the twintercooler. Not sure how effective it will be for the price. S3 cooler is pretty good as it is. I do know a few guys down here who've gone with water/meth injection as the next mod and its been working great for them
  27. jonnyc
    jonnyc Member
    858
    Ahh I do have some plans which will include fitting an uprated fuel pump if you know what I mean :scared2:
  28. phantom
    phantom On Boost
    1,750
    BT on the way? LOL
    The fuel pump cars are hitting peak power at 4500k revs and holding it to the limiter...must be fast.
    p
  29. jonnyc
    jonnyc Member
    858
    I would say BBT really.. :)
  30. sakkie69
    sakkie69 2008 Audi S3
    199
    MotorCade in South Africa who does all the Ford ST induction also does S3 induction kits now for almost half the price of the Forge it seems (saw link on the AudiClub of SA). A pipe is a pipe is a pipe no?
