S3 holding back on power... any ideas?
lloydsta101 Jan 10, 2010
  1. lloydsta101
    lloydsta101 Member
    134
    Hi guys,
    I've had this problem for a while now and originally thought it was clutch related, but I've now had this done and still have the problem. It's not all the time that it happens, but it's becoming more and more frequent which is frustrating.
    Basically, when I'm accelerating in pretty much any gear, the revs shoot up to around 40 and the car feels and sounds like it's holding back in power quite badly. The revs then drop back down to around 30 and it slowly builds back up again. It mainly does it if I want to suddenly put my foot down a bit without dropping a gear, which should be a fairly easy task for the S3.
    It hasn't always done this, only for about a month or so and it's getting annoying... especially when I'm following someone else and they decide to pull ahead leaving me fighting for power behind. I've had it plugged into VAGCOM and it doesn't come up with any faults, other than Secondary Air Pump which has now been fixed, cleared and hasn't come back.
    Any ideas will be greatly appreciated! Cheers, Sean.
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,249
    2,072
    It could be a boost leak,check the miles of un-necessary pipe in your engine bay ;)
  3. lloydsta101
    lloydsta101 Member
    134
    Yeah, I'll have a look tomorrow. Could it be anything to do with the N75 Valve do you think, I've heard that it can cause boost problems if faulty?
  4. voorhees
    16,249
    2,072
    an upgrade to the N75 'J' version is worthwhile as its 30 quid and if you look at ess threes performance testing it gives more so do it
  5. lloydsta101
    lloydsta101 Member
    134
    Hmm, yeah I might do that. Just noticed a recent thread about another member upgrading to the 'J' valve... where can I get one of these from?
  6. ash3435
    ash3435 flat out if in doubt
    148
    psi do them for around 50 pound.they have a website psi tunning.com
  7. lloydsta101
    lloydsta101 Member
    134
    Where do you get this from for £30 voorhees?
