S3 holding back in 2nd during hard runs
eightfour7two Jan 11, 2014
  1. eightfour7two
    eightfour7two Member
    46
    Hey all,
    Whenever I'm doing a hard run, the car always holds back right after the shift into 2nd gear. The engine management light flashes and the revs seem to climb extremely slowly despite the pedal being to the metal!
    Is this normal on the S3? It doesn't happen if you build revs rather than plant the right foot. I've scanned it with VCDS and it shows no faults. I logged RPM, mass airflow, boost and N75 duty (excel spreadsheet here) during a run but don't really know what to look for.
    I originally figured it was a misfire due to bad coil packs, but shouldn't that kick out a fault code?
  2. Vex182
    Vex182 Guess what I drive...
    1,035
    79
    Is it the Ecu light flashing or is it the traction control? That can flash after a hard go in 2nd and cut the power.
  3. eightfour7two
    46
    Ah my mistake, yeah it's the traction control light that flashes. I'll take that as normal then?
  4. Vex182
    1,035
    79
    It can be, if you turn it off then it will help. Mine does it after about 6k in 1st and 4k in 2nd, usually when it's wet or damp out.
  5. eightfour7two
    46
    Good lord, what a mong! I spent my saturday evening in my work's business park doing 1st and 2nd gear runs with my laptop hooked up when it was just the ESP doing its thing! I guess that's what you get when you come from a Peugeot derv without so much as ABS!
  6. :: blade ::
    :: blade :: Active Member
    343
    31
    i had the same happen to me going up a sliproad going onto a m55 going to overtake a **** doing 20 floored it and got into third and felt like i hit a was. since then the tc is turned off if i need to do some hard driving :)
  7. Av4nt
    Av4nt Well-Known Member Team V10 Team Sprint Audi S6 quattro s tronic saloon
    1,511
    386
    Lol! Ah well at least it wasnt a bad thing afterall.
  8. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    coilpack didnt throw a code on mine mate. if its not running rough on idle already and it is coilpack eventually it will break completely, it will sound like youve blown her up so dont panic and nurse it home lol!
