S3 - High milers
darkfibre Jun 23, 2010
  1. darkfibre
    darkfibre Member
    94
    Hi all,
    Is 104K considered a high miler for a 2002 8L? Cambelt done at 75K, thinking of getting my first S3 so would appreciate some advice on the mileage and also whether it's time for another cambelt change.
    Thanks in advance,
    darkfibre
  2. Speedy Steve
    Speedy Steve Active Member
    1,258
    Nope im at 113k and just going hybrid and stage 4 map it all comes down to how you look after the car
  3. S3 Rav
    S3 Rav Well-Known Member
    2,825
    30
    Agreed with steve. Mines hit 100000 miles and still going strong. As long as it's serviced regularly it should be fine. Depends when cambelt was done last I would imagine.
  4. darkfibre
    darkfibre Member
    94
    The one I'm looking at says it was done at 75K - now sitting on 104K - when would a change be necessary?
    Sorry, I'm a Renault guy looking to make the transition :p
  5. Broken Byzan
    13,237
    465
    When was it done? Date wise. As its due around every 75 k or 5 years whichever comes first,so it could be a bargaining chip.
  6. darkfibre
    darkfibre Member
    94
    Not sure mate, gonna get on the blower to find out.
    Anything else worth asking? I'm gonna call him in 10 mins.
  7. sportquattro
    sportquattro Active Member
    845
    51
    Ask if the water pump was changed at same time, it should be done then as a profalactic measure as its much easier to do it iin one job.
  8. darkfibre
    darkfibre Member
    94
    Yeah I believe it has, but will pose the question.
    I've done various searches, but is there a S3 buyers guide lurking around here somewhere - what to look out for? Wouldn't mind studying that in depth - could someone point me in that direction please?
  9. Matt82
    Matt82 Active Member
    2,365
    lol @ 104k being high
    barely born
  10. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    When you're buying, 104k is high.
    When you're selling, 104k is just boken in.
    In reality it's all about how much TLC the car's had in this time.
  11. Matt82
    2,365
    someone would have had to do something despirately bad to a car (like AVS haha) if it was shot at 104k
  12. Prawn
    11,602
    3,573
    104k is nothing on a 20vt really, my old car was at 202k when I retired it from dailly use and the engine was still fresh as ever
  13. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    As above make sure the cambelt & waterpump has been done. My S3 is on 202k now; check out this thread for some other areas to look at and barter with.
  14. Matt82
    2,365
    youd be swapping your S3 for what exactly? ;)
    v. bar·tered, bar·ter·ing, bar·ters
    v.intr. To trade goods or services without the exchange of money.
  15. Westy
    Westy Well-Known Member
    17,443
    1,105
    Mine was bought on 104K, all motorway milage and the cambelt was done at 75k in september 2007. Here we are 3 years later and its now on 118K and about to get its 2nd cambelt done. Because of all the motorway milage the clutch and turbo are still in good nick, the suspension however, is shagged :banghead:
  16. indiemike
    indiemike ZoomZoom
    388
    My mates running his S3 with 150k, tight as a drum and runs great
    Like anything, if its looked after well it will keep on going
  17. Ditto to all of this... mines on 145k with mostly motorway miles - compression check last week showed all around 11.5.
    Well looked after, serviced regularly with good oil, preventative maintenance approach and you can't go wrong. I'd check it's not been on the Audi Variable, i.e. longer period, Servicing tho. and if it's too late, cos you've bought it now, I'd get it off that ASAP!
  18. Matt82
    2,365
    ive got an old 16v golf. i compression tested that a coupe years ago, it was on about 198k miles. the compression figures were just below the top boundary given by VW
    basically, on a higher mileage car all youve got to worry about is consumables needing to be replaced. obv some consumables are easier to sort than others, but engine wise it should go on indefinately.
  19. darkfibre
    darkfibre Member
    94
    Thanks for the replies guys. I done the deed and bought it. Picking it up midweek next week :)
  20. paneristi232
    paneristi232 Member
    80
    Congratulations!!!!! You won't be disapointed.
    J
