S3 High flow cats
imported_glen_jai Dec 1, 2004
  1. Hi,
    Can anyone who's had a high flow cat fitted to their s3 or TT tell me if the 100 cpsi cat passes the mot emissions test, or do I need the 200 cpsi one?
    Thanks,
    Glen
  2. DavidR
    DavidR Active Member
    1,296
    I had 100cell cats which *just* passed the emissions test, and after a year or so kept bring on the engine check light due to "catalyst below effeciency". I know have 200 cell cats.
  3. amb276s3
    amb276s3 bird spotter
    292
    What cell type is the miltek, my 1st test due shortly, no dash lights tho after 15 months.
  4. s3bow
    s3bow Member
    381
    Hi mate, got a single 100 cell cat on my S3, same one as AndyTQ I believe. No check lights yet. Tell you about the emmissions in March though(first MOT)! As for performance, there was definitely an increase, whether it was worth the £500 for the d/pipe and cat I'm not sure. Haven't tested it so don't know how much increase. Plenty of open area though. Read a number plate through it ! There's a guy named Simon Elman got the d/pipe and cat by Hayward&Scott. Not sure whether he has the single cat though.
    Chris.
  5. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    Ive got Milltek sports cat... Not sure if its 100 or 200cpsi. I'll tell you about emissions as mine going to MOT next week /ubbthreads/images/graemlins/cry.gif Fingers crossed!
    Rich
  6. HTC
    HTC Active Member
    3,428
    9
    [ QUOTE ]
    Rich
    [/ QUOTE ]
    Let us know as I've got the same one as you!
  7. RichA3Turbo
    5,089
    [ QUOTE ]
    HTC said:
    [ QUOTE ]
    Rich
    [/ QUOTE ]
    [/ QUOTE ]
    Is it 100 or 200cell?
    MOT is tomorrow morning... Ifs not within limits then i've got 2 weeks to do something about it... Dont know what mind!
    Rich
  8. HTC
    HTC Active Member
    3,428
    9
    I've sent an email to Jon at Milltek to find out. I'll let you know.
  9. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    Ok... Cheers
  10. s3withproblems
    s3withproblems New Member
    21
    Which one is the engine check light ? I have a direct flow cat in my 2001 s3? Does it cause problems except the emission tests?
  11. RichA3Turbo
    5,089
    [ QUOTE ]
    [/ QUOTE ]
    Picture of an engine with a lightning bolt through it
    Rich
  12. HTC
    HTC Active Member
    3,428
    9
    Rich,
    Just had an email from Jon. Our cats are both 200cell.
  13. RichA3Turbo
    5,089
    Cool.
    Thanks for finding out. MOT should hopefully be ok then!
    Rich
  14. StevieBogan
    StevieBogan Member
    144
    [ QUOTE ]
    Chris.
    [/ QUOTE ]
    Alright Chris,
    what make is your down pipe and CAT? Is it 3"?
    I thought the only people that made one of these for the S3 were APR?
  15. Hi everyone,
    Thanks for all your response. I've heard that there isn't much performance to be gained in fitting one, so I might give it a miss, as it's not cheap at almost 900p for a Milltek.
    Paul's probably right, it's change for the sake of changing.
  16. ANDYTQ
    ANDYTQ Well-Known Member
    1,186
    106
    Stevie,both our front pipe and cats were custom made by a stainless guy in cardiff.Stevie's i think is 3",mine is 2.5 inch front pipe and 3"cat into 2.75 "milltek.He has also done 2 LCR 's with a full 3" system,one 210 and a jabba 225 /ubbthreads/images/graemlins/beerchug.gifAndy
  17. s3bow
    s3bow Member
    381
    Hi Stephen, as AndyTQ said it was made by a custom exhaust builder in Cardiff called Z-Ex. It's 3" coming out of the turbo turning down and back towards the bulkhead. Space gets quite tight when it gets to the prop so it has to go to 2.5" for about 8" before opening out to 3" into the cat. Cat is Rosi as used by GGR. APR one is a bit expensive I think.
    As I said previously there's a guy called Simon Elman with quite a powerful Imola you probably know had his d/pipe made by H&S. Worth calling them to see if they made a pattern. Maybe Z-Ex could make a jig from mine. Think they would probably want about 600 for d/p and cat. Sounds better than a grand+vat. Problem is the car was never put on a rolling road after I had it mapped so I probably wouldn't know how much it gives. Def feels better though.
    Hope this helps, even if it is a bit vague.
    Chris.
  18. StevieBogan
    StevieBogan Member
    144
    S3bow,
    thanks for the reply. Do you have there number?
    Also, who chipped your car? Did they chip it to take into account the d/p or was it an off the shelf remap?
    Sorry about all the questions, just very interested in this subject!
    Stevie
  19. s3bow
    s3bow Member
    381
    Stevie, the number is 02920455265. Haven't had the car mapped to suit the d/pipe yet, probably make a fmic first although I'm not sure the gains a custom map would produce would make a great difference on the road. Ten horse power on the road probably wouldn't be a major increase in performance. Having said that the car has a Superchips file which isn't held with a great deal of regard with some on here. 1.5 bar peak settling to 1.1-1.3. Have to get the car on a rolling road,get some figures.
    Chris.
