S3 Hesitation / surging issues
mattyboy199 Mar 19, 2013
  1. mattyboy199
    mattyboy199 Well-Known Member
    1,892
    30
    I recently replaced my plugs due to hesitation / surging issues & initially all was good however in higher gears 3rd + it has re-occurred. Today the EML light was flashing I haven't scanned it but I am already aware of the lambda sensor number 2 being faulty, this hasn't affected MPG & I do not believe there causes any adjustment in the fuelling made by the ECU. When I previously removed the lambda sensor it was black & easily wiped clean my intension was to cure the hesitation issue then clean up the lambda probe however i'm at a bit of a dead end. The coil pack wiring loom is all good the only thing which springs to mind is coil packs & although their 50k old they look in good condition (not cooked / tarnished).
    Anyone else had this problem ? i'm concerned it could be a turbo issue.
    Regards
    Matt
  2. mattyboy199
    1,892
    30
    I'm planning to do some VCDS logging today so hopefully this will highlight the issue.
  3. Paradox1
    Paradox1 Active Member
    1,833
    88
    possibly a boost leak?
  4. mattyboy199
    1,892
    30
    hmmm...this says coil packs to me, the 17526 & 17522 are related (lambda) not sure about the 17705...
    Gonna switch over coils 3 & 4 with 1 & 2.
    VCDS-Lite Version: Release 1.2
    Wednesday, 20 March 2013, 18:53:55.
    Chassis Type: 8L - Audi A3/S3
    Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
    Address 01: Engine Labels: Redir Fail!
    Controller: 8N0 906 018 BH
    Component: 1.8L R4/5VT 01 0001
    Coding: 10710
    Shop #: WSC 00000
    7 Faults Found:
    17526 - Oxygen (Lambda) Sensor Heating; B1 S2: Open Circuit
    P1118 - 35-00 - -
    16684 - Shareware Version. To Decode all DTCs
    P0300 - 35-10 - Please Register/Activate - Intermittent
    16685 - Shareware Version. To Decode all DTCs
    P0301 - 35-10 - Please Register/Activate - Intermittent
    16688 - Cylinder 4: Misfire Detected
    P0304 - 35-10 - - - Intermittent
    17522 - Shareware Version. To Decode all DTCs
    P1114 - 35-00 - Please Register/Activate
    17705 - Shareware Version. To Decode all DTCs
    P1297 - 35-10 - Please Register/Activate - Intermittent
    16687 - Cylinder 3: Misfire Detected
    P0303 - 35-10 - - - Intermittent
    Readiness: 0010 0001
    Address 03: ABS Brakes Labels: None
    Controller: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E0FBDFB296F
    No fault code found.
    Coding: 18448
    Shop #: WSC 01236
    VCID: 3E0FBDFB296F
  5. mattyboy199
    1,892
    30
    Coils switch last night, faults codes found below.
    16684 Random/Multiple Cylinder Misfire Detected
    16685 Cylinder 1: Misfire Detected
    Cylinder 1 has coil 3 in it, this makes sense to misfire. What I don't understand is why cylinder 2 (previously coil 4) & 3 (previously coil 1) have not misfired.
    I need help please guys !
  6. mattyboy199
    1,892
    30
    As suspected 4 x new TFSI coil packs cured this problem HAPPY TIMES !
