s3 Help!
nailer Mar 24, 2013
  1. nailer
    nailer New Member
    hi am new to furom as i just bought an s3 and already require advice/help.
    First thing is vibrating over 50mph and its bad but steering wheel is fine so am sure its from rear and i have ballanced all wheels and tyres they dont seem out of shape either so next step was to put it on 4 poster ramp and jack the hole car up and put it in 6th gear and get it to 50 mph with no rear wheels and still the same so i thing thats put wheels out of the question?
    I also noticed when on full lock i.e parking its crabbing is that haldex clutch sticking?
    Thanks all in advanced
  2. mark_S3
    mark_S3 Team Silver
    805
    299
    My opinion would be to get it booked in for a full 4 wheel alignment to see if the back end is straight!
    If it's crabbing usually suggest it ain't straight, or you got problems with the rear axle been out of line!
  3. downhilldave77
    downhilldave77 Member
    51
    hi wecome to the forum. one of the symptoms of the haldex not working are the back wheels dragging when doing three point turns or on tight turns have a search there is loads of info on here :thumbsup:
  4. nailer
    nailer New Member
    If back end wasn't straight would it still vibrate with all 4 wheels off the ground and with no wheels on ?
    also when turning on full lock and turning rear end feels like a BMW with a welded diff? is it worth doing haldex oil and filter?
    thanks again guys !!
  5. <tuffty/>
    21,577
    4,049
    http://www.audi-sport.net/vb/a3-s3-forum-8l-chassis/176598-haldex-always-locked.html
    Oil and filter change may help you as this is sometimes the cause of issues with haldex clutches... servicing tends to get over looked on older cars as the owners don't take them to dealers due to costs and local garages are blissfully unaware they exist...
    Precharge pump and haldex controller being the other prime candidates for this... what you can try is to pull fuse 31 (5amp fuse) which is the haldex fuse and see if it stops dragging... if it does then the last one I seen with that issue was fixed by replacing the haldex controller...
  6. nailer
    nailer New Member
    Thanks tuffty once I open garage in morning ill pull fuse and try it, it's fine in normal driving and cornering seems fine just on full lock if u let off full lock slightly it doesn't do it but defo worth a try and if it is a problem am not scared of stripping and rebuilding it :)
    just could do with getting to bottom of vibration now :-(((( without spending at guessing
  7. Lewis583
    956
    91
    I would give the propshaft centre bearing a look over too.
  8. nailer
    nailer New Member
    thanks Lewis overlooked that had a BMW that did that ill look in morning and update thanks guys for all you time and help!
  9. nailer
    nailer New Member
    Update found a bolt out of propshaft to front transfer box/gearbox think am all sorted :) ordered from tps
