S3 Heated Seats
gilberto May 14, 2013
  1. gilberto
    gilberto Member
    156
    Evening all,
    I had my heated seats on today at the highest setting and i was a bit dissapointed with the heat produced, it was warm but i'd say colder than the lowest setting on my Z4M seats, should the seats be warmer on the hottest setting? Perhaps something isn't working properly?
  2. monopole
    monopole Well-Known Member
    1,154
    466
    Mine don't seem to be as "hot" as my TT was on the high setting (TT had 3 positions, S3 has 6!!!), but hey, they do the trick.
  3. ramp1990
    ramp1990 Member
    81
    13
    I cnt have mine on 6 for too long burns my bum lol there roasting :)
    batch likes this.
  4. NickB
    NickB New Member
    25
    Had mine on 4 this morning and had to turn it down to 3 as it was too hot.
  5. Wicked666
    Wicked666 Active Member
    584
    35
    My s3 seat heaters take a while and are not very hot. Had them on max over most of the winter. May need to check the passenger side to see if anything is up with the drivers side
  6. 37
    37 Member
    129
    Silly questions chaps - How difficult is it to get non-heated seats converted to heated? Do I have to change the whole seat?
  7. shady-ninja
    shady-ninja Active Member
    999
    53
    do you realise that the hotter settings can fry your testicles and reduce your ability to produce viable sperm?
  8. Ash187
    7,443
    704
    so on prefacelift (2004-2008) the heated seats burn hotter than the facelift cars (2008-2012), not sure why they changed it like that but its how it is.
    as for retrofitting it the easiest way is to get seats that already have the heated elements in them, otherwise you would need to strip down the seats and install the heated pads which are hard to come by and expensive
  9. Tempy
    Tempy Member
    157
    15
    I have S3 heated seats retro-fitted into my 58 plate. Even at level '6' they don't get too hot. If I remember correctly, when Ash had VCDS plugged in, they rose to just over 30 degrees, which when shielded by leather, aren't that hot. Still very nice on those cold wintery mornings though. A very worthwhile mod.
    As Ash says (he helped me do mine) retro fitting heated seats is the cheapest option. it's actually cheaper than you think. If you already have leather, they will sell for a decent price to offset the cost of the replacements with heating elements. I swapped my half leather S Lines for heated full leather S3 seats and after I'd sold my old ones, I'd only spent £50 swapping them out. I fitted them myself as it's very easy.
    Bear in mind you will also need a new climate control with heating controls and a wiring loom, oh and someone to do the wiring unless you're confident yourself. I can certainly recommend Ash as he did a top job wiring up mine.
    I sourced the climate unit from the same S3 the donor seats came from and sold my old unit for the same price. Free upgrade :)
    The Kufatec wiring loom is a bit pricey for just a few bits of wire and plugs, but worth it for that nice "I've just wet myself" warm feeling that only heated seats, or actually pissing yourself can provide.
    Fitting heated seats also cured a whining noise I was experiencing. Basically my missus complaining that my leather seats were too cold :blahblah1:
    Ash187 likes this.
  10. Ash187
    7,443
    704
    HAHA classic!
  11. gilberto
    gilberto Member
    156
    Does anyone find it's just the bottom part of the seat that heat up and not the backrest?
  12. Audi Dynamik
    Audi Dynamik Well-Known Member
    2,218
    308
    If i have flatulence this seems to be the case :whistle2:
  13. blackshuck
    blackshuck Member
    440
    I can put my dial on anything from 1-6 and my arse is still cold!
    I have the dials but no heating elements in the seats!
    Cheers Audi!
  14. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    72
    On mine 6 is good for five minutes to get warmed up.
    Then down to 3 it's just right. Any less than 3 is pointless IMO.
    Mine is a 2007 57 model :)
  15. wuta3
    wuta3 Well-Known Member
    1,124
    345
    If it is a MK1 TT, those seats induced a good ball sweat after 2 seconds at highest setting! lol
