S3 Headunit Upgrade
carman Jun 7, 2005
  1. carman
    carman New Member
    19
    Hi All
    I am looking for very smart mp3/CD Headunit for my S3.
    Has anyone got any recommendations? I am willing to spend top money but would ideally like for the illumination to be in red (to match the red dials!!)
    Also when fitting an aftermarket headunit what do i need exactly? I have been told i need some blank spacers, where do i get these from and how much are they? Do i need anything else???????
    I would appreciate any help!! /ubbthreads/images/graemlins/wink.gif
  2. AndyMac
    9,832
    45
    Whichever model you choose you'll need the following:
    Fascia adapters (blanking plates) available from Audi Dealer approx £10, the back of which will need to be trimmed to fit otherwise they stick out.
    Antenna amp
    aerial amp
    HU removal keys - Audi dealer , ebay or big Halfords/ICE dealer
    On the wiring front it really depends how you plan to hook everything up. You can just buy a wiring adapter which will allow you to plug the standard RCA pre-outs into the Audi loom for the rear speakers and the sub (the front speakers are on a standard ISO speaker block). This will also give you a loud "pop" everytime you turn the unit on or change CD tracks & possibly engine whine (at no extra charge).
    The preferred method is to bypass as much of the Audi wiring as possible and wire the rear speakers directly to the new HU speaker outs, but you'll lose the sub unless you buy the adapter above, (the pop is bearable when it's just the sub). Again it's strongly recommended to replace the tupperware sub with something that actually works (stealth sub or proper boot hogger), and also replace the front component speakers.
    If you have the Bose upgrade then the above is all still valid but you'll cook the HU if you run any of the Bose 2 ohm speakers off the HU's internal amp.
  3. carman
    carman New Member
    19
    Thanks Guys /ubbthreads/images/graemlins/wink.gif
  4. Nessy
    Nessy VW + Audi mad
    834
    56
  5. What unit do you have at the moment? have you not considered an Audi RNS-E DVD nav upgrade, it will give you mp3 playing from 2x SD slots. 2GB cards are available, 4GB total. Plus you get Navi, CD chnager option and TV tuner options and it matches your car.
  6. Depends on whats needed, I'm doing the upgrades for £1000
  7. AndyMac
    9,832
    45
    Exactly!
