S3 Headlights
RmcMills Jul 26, 2009
  1. RmcMills
    RmcMills Member
    34
    Does anyone know if or how you can remove the headlight glass from the main headlight part? :uhm:
  2. 20vtmk3
    20vtmk3 Member
    76
    Ive read that peaple heat up the headlamp glass and then carefully prise it away from the main headlamp bit. A few have done it to paint the inside of their headlamps. Hope this helps. Im thinking of doing it to replace my lenses because their covered in stone chips, just need to get hold of some new lenses if i can
  3. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    No need for new lenses mate. Get yourself some wet and dry and sand the marks out. Get down to about 2000 grit or even up to 3000 if you have the time and then polish them clear.
    I did the ones on my brothers Civic a few days ago and they're better than brand new :)
  4. LiveWire
    LiveWire S3X
    329
    One of my headlights is discoloured (yellow tinge)
    I would also like to know if the lens will come off?? so I can try and clean the inside, Dont want to buy a whole new light.
  5. s3ollie
    s3ollie Member
    762
    I have got a set of new halogen lamps facelift shape if your interested. different insides but same lenses. they have some broken parts inside that hold the bulbs but if you only want the lenses....
  6. 20vtmk3
    20vtmk3 Member
    76
    A3Tom, never heard of anyone doing that before. Are you sure the same would work on the s3. Arent the lenses plastic???
    s3ollie, Would be interested if i cant sort them any other way, they really do look pants when marked and spoil the look of the front end
  7. RmcMills
    RmcMills Member
    34
    Cheers guys, the reason i was asking...
    I was thinking of putting LED running lights along the inside of the lens, like the new A5 etc has, What would you reckon to this, or too chavvy?
    P.S please dont lynch me if you disagree! lol
  8. Az
    Az Hard slammed!
    1,023
    34
    I'm thinking of tinting the inside housing of my facelift headlights as well, I know a lot of people do it on their civic's by putting the lights in a moderately heated oven for a few minutes to soften the silicone and then price the pence off the cluster.
  9. NHN
    29,328
    1,708
    Yes you can use a heat gun to soften the sealant up to split the lense & main plastic housing, you can also stick it in the oven for few minutes, but I would use the gun personally as I did on my headlights some time back, just take time cause can melt the plastic easily trust me.
  10. Az
    Az Hard slammed!
    1,023
    34
    I think the day time led lights would look good! As long as they are done well, if they are bodged then they'd look cack in my opinion. Only thing that would worry me is if a couple of the led's blew, then you've got the massive hassle of taking them all apart again.
  11. RmcMills
    RmcMills Member
    34
    Right thats convinced me i'll get it done sometime in my MONTH off for summer leave at the end of this week then, Let you know how it goes!
  12. 20vtmk3
    20vtmk3 Member
    76
    Personally mate i think your car looks great as it is, i wouldnt spoil it with some A5 lookalike lighting. Only my own opinion though!
  13. <tuffty/>
    21,009
    3,770
  14. ash_pearce
    ash_pearce Member VCDS Map User
    321
  15. IIIadidasboy
    IIIadidasboy Member
    312
  16. Nilz
    11,329
    876
    It can be done, if you do a search, you will find that someone has done it with his foglights and the end result is excellent.
  17. 20vtmk3
    20vtmk3 Member
    76
    Thanks, Ill give it a go this weekend if i get a chance. Ill keep you posted
  18. 20vtmk3
    20vtmk3 Member
    76
    Finally done my headlamps, they look amazing. I never thought they would come out so good. Started off with 600 wet and dry paper to get rid of the worst chips and scratches and worked through the grits to finish with 1500 grit, then used a rubbing compound and finally some normal polish. When i first started with the 600 i thought i had completly knackred the lights up, they just went a hazzy white and i didnt think i would ever get them clear again but after ages of rubbing down they looked brilliant and only cost a few quid to do. Result!!!
  19. S3 HODGE
    S3 HODGE Brown passenger seat.
    1,200
    Sounds good well done, Get some pictures up :)
    You didnt attempt to take them apart and spray them then?
  20. 20vtmk3
    20vtmk3 Member
    76
    No, i never intended to spray them just wanted them looking like new again. Will try an get some pics up a.s.a.p
  21. 20vtmk3
    20vtmk3 Member
    76
  22. 20vtmk3
    20vtmk3 Member
    76
  23. 20vtmk3
    20vtmk3 Member
    76
    All [​IMG]done!!!
  24. ianysm
    ianysm Active Member
    1,002
    Wow, looks great...The first pic you put up i thought looked terrible until i saw the rest and realised that was a 'before' pic!
    So where did you get the paper from...Halfords?
  25. ianysm
    1,002
    Out of interest, anyone know where i can pick up one of the rubber pieces that sit above the light and what the bonnet sits on? I have one missing!
  26. 20vtmk3
    20vtmk3 Member
    76
    Cheers mate, yeah i did put up the pics the wrong way round, doh. You could get one of them from the dealers or just go round some scrap yards for a look
  27. 20vtmk3
    20vtmk3 Member
    76
    Sorry forgot to say i bought the paper from halfords which only goes down to 1500, but someone said that you can get 2000-3000. 1500 worked fine for me with rubbing compound.
  28. S3-Andy
    S3-Andy Member
    204
    I need to split my lights on the S3 as i somehow managed to drop the side light bulb inside when i was removing it!
    So if anybody has done this could you please let me know how much of a chore it is or if anybody has any tips as to how i could remove it without too much hassle please let me know
    cheers
  29. rossbrownlee
    rossbrownlee Ross_S4
    719
    S3 Andy is that facelift or prefacelift?
    If it is prefacelift then yes it is really easy.
  30. S3-Andy
    S3-Andy Member
    204
    its the facelift mate
  31. rossbrownlee
    719
    no idea then mate sorry, easy on the pre-facelift.
  32. s3ollie
    s3ollie Member
    762
    just remove the light unit from the car and you will be able to get the bulb out through hole at the back
