s3 headlight parts
sportstractor Jul 25, 2011
  1. sportstractor
    sportstractor Chugger
    2,709
    Could any of you fine gents tell me if any interrnal parts for s3 headlights are available,
    I had my headlights out yesterday to remove pitting and I found that the clip that attaches the inner unit to the leveling motor had broken.
    This bugger:
    So obviously headlight leveling isnt working, tried repairing it but it just breaks when you refit it. Can you get a replacement?
  2. superkarl
    superkarl MAN OF STEEL
    9,428
    2,396
    As far as im aware you cant.
    See my thread 'superkarls overhaul'
    I acquired some clips which are very similar. I've already sent 2 out to Ian_w on here, but havnt heard back from him yet. I have 2 more but they are going to dani b (sorry I havnt replied yet, but I have some for you to try).
    Il get some more for you matr and let you know, like I said tho, I don't know if they work yet, but they should do.
  3. Westy
    Westy Well-Known Member
    17,443
    1,103
    I'm in the exact same boat mate. I took my headlight out and found that the which stick with the ball on the end that is meant to fit in that clip wasn't in it so I tried to push it in and broke the clip :(
    Did you open up your head light by heating it?
  4. Dani_B19
    9,168
    363
    Haha was about to just say you get my email karl, how much do i owe you?
    Also, i need to split my headlights, whats best way? Oven? Haha.
  5. Westy
    17,443
    1,103
    I've heard oven, gas mark 4 for 20 mins then add in a red wine sauce and allow to simmer. If you're feeling adventurous you can add some sliced garlic or onion ;)
  6. sportstractor
    2,709
    could possibly do with a couple if you could manage it, I think only one is gone, but i better had check the other, they obviously go very brittle over time.
    no i just twisted out the motorised adjuster thingy and fished it out, iv also managed to put one back in place, but it broke once i tried pushing the ball it, i honestly dont think its nescessary to split the units...
    almost worth buying a new set..
  7. sportstractor
    2,709
    HAAAAAAAAAAAAAAAAA!
  8. Westy
    17,443
    1,103
    I found it really difficult to get the ball back in the clip and this is how I broke my clip :(
    How much are a new set of headlights???
  9. Dani_B19
    9,168
    363
    Think about £600 each side, give or take.
  10. Westy
    17,443
    1,103
    **** that! I'll try and find a 2nd hand headlingt for sale.
  11. superkarl
    9,428
    2,396
    I could do with hearing back from ian on whether he fitted them and they worked, but i hvnt seen him on here in a while.
    I still need to fit my own too lol.
  12. Dani_B19
    9,168
    363
    Haha good luck, ive bought a3 ones and going to fit a HID kit, cost so far is about £100 :).
  13. BENJAMIN
    BENJAMIN Active Member
    503
    93
    just checked ETKA clips not available separately........ lame
  14. sportstractor
    2,709
    well they look like they are designed with the adjuster in mind... you should be able to just pop the adjuster in, you obviously need to pull the inner unit back against it. Its certainly not impossible, definately not worth splitting the unit, that could end in major hairloss.
    i may make my own clips with a bit of ally and a C shaped pin... bit of a ballache though.
    I though ECP did them for £150/side?
  15. Westy
    17,443
    1,103
    Trust me I tried for ages and even checked ELSA for instructions, the fecker wouldn't go in easy.
  16. sportstractor
    2,709
  17. sportstractor
    2,709
    i believe you mate, i just assumed they went in easy. I pushed mine in, but it broke the clip in the process... il put my thinking cap on and report back
  18. Westy
    17,443
    1,103
    That's exactly how mine broke. God knows hoq it came out in the first place? Let me know what you find mate.
  19. sportstractor
    2,709
    Well iv managed to repair my clip! it had split down the middle so I glued it back together then cut some grooves in the plastic webbing, and wound a coil of copper wire around it to hold it together while I pushed the ball joint back in, and it's worked a treat! Better had get back to work now
  20. Westy
    17,443
    1,103
    Good work that man :applaus:
  21. sportstractor
    2,709
    Thanks! I'm genuinely well chuffed!
