s3 headlight adjustment???
S3-Chris Aug 31, 2008
  1. S3-Chris
    S3-Chris If its not broke....break it!!
    303
    61
    help! as above on 2001 s3 the headlights are very low, and i cant see jack in the dark, but how do i adjust them to make them higher??
    any help would be appreciated!
    chris
  2. S3 Wannabe
    S3 Wannabe Member
    197
    have the same problem! well anyone????
    read on another recent post, there is an alan key adjustment -is this true/false?
  3. S3Steve
    S3Steve Active Member
    1,612
    17
    Height can be adjusted via one of the two white allen key adjusters you will be able to see on the top of the headlamp, one adjusts up and down the other adjusts the beam left and right.
  4. S3 Wannabe
    S3 Wannabe Member
    197
    cheers mate! have adjusted and now look forward to my next journey at night!:applaus:
  5. S3-Chris
    303
    61
    i'll try later, thanks
  6. Nuri
    Nuri Member
    34
    I thought the HID's were self leveling?
  7. S3-Chris
    303
    61
    i've tried adjusting the white alen key nuts and no joy, i tried it against my dark garage wall.... is this a specialist job or what.... any ideas??
    chris
  8. glen_jai
    glen_jai Member
    340
    Hi Chris,
    I have the same problem on my headlight too at the moment.
    I've just replaced my xenon motor on the offending side, but still no luck.
    You have to do the adjustment while it is in "learn mode".
    To do this, you need Vag-com. Follow this:
    http://www.ross-tech.com/vag-com/cars/xenonalignment.html
    However, this did not work for me. When I have set the headlights to "learn mode", it appears that I cannot adjust the offending headlight any higher. You may have the same problem, as I would doubt your headlight would point at the floor for no reason.
    Have booked my car into the dealer for investigation. As I've changed the xenon motor and done a headlight alignment with no joy. So gonna bite the bullet and hope the knowledgeable boys at Audi know why.
  9. S3 NIK
    S3 NIK Member
    190
    I had the same problem with both headlights. A friend of a friend had to plug his laptop in and reset the headlights to there default position and they have been fine ever since.
    (No parts were replaced by the way)
    Nik.
  10. glen_jai
    glen_jai Member
    340
    Sorry to revive this thread but I am still unfortunately suffering headlight alignment issues.
    The car has just been into my local dealer and they have supposedly fixed the alignment issue I was having for a princely sum of £165.
    The dipped beam is now fine, but it now appears that when I put my high beam on, it just shines into the sky.
    Does anyone know how to fix this?
    I thought there was no adjustment for the high beam, and that it was just a relative aim to the dipped beam.
    Cheers,
    Glen
  11. grumbas
    grumbas Member
    49
    Sorry for the hijack, but I'm having a slightly different problem with mine, the height appears fine on the garage wall, but the top of the beam is flat as if it's been adjusted for driving on the continent rather than sloping up to the left as you'd expect.
    Also they seem to vary between being normal brightness and very dim - at times it can appear as if I've got little more than sidelights on!
    Any ideas anyone?
  12. <tuffty/>
    21,016
    3,780
    I too have the problem of them only illuminating a few metres in front on dipped. Bit worried about the cost tbh... £165 seems an awful lot for adjustment... can this only be done by a computer???
  13. golf
    golf ***** rent boy VCDS Map User
    1,556
    The simple solution is to adjust the little white screws on top of the headlight. This will nearly always work unless the screws are damaged.
    Make sure it's properly dark so you can see the beam, and be certain you're adjusting the beam height and not left/right. A few turns in the right direction and you will see the beam raise. Don't overdo it as you'll be blinding people.
    You might need VagCom so the motors don't go back to their normal position after you've adjusted them.
    As a side note, the xenons on the S3 are dire.
  14. jesters3
    jesters3 Active Member VCDS Map User
    1,516
    I have this exact same problem at the moment, so if anyone does have a fix please let us know!:thumbsup:
  15. Wernlas
    Wernlas New Member
    25
    I had exactly the same problem!
    took it into Audi and they said they'd adjusted it, that night, dipped was fine (as it was when I took it in) but my drivers side main beam was pointing into the tree tops!
    took it back again and they removed the light and showed me that the badly designed white allen key screw things that become brittle and extremely stiff were just spinning on the serated spine in the middle!
    they glued it and said they'd set it again so I went and parked directly infront of a warehouse about 20 feet away after picking it up. dipped was still fine but drivers main was obviously a good 8 to 10 inches higher from just 20 feet! gave up with Audi at this point
    that night I parked it about 25 feet away from a brick wall (perfect for setting lights) and spent about 2 hours adjusting then testing on the road then adjusting again and so on
    it's perfect now for both dipped and main
    I don't get it, the adjustment moves the whole light so why is dipped perfect and main so far out
    when I was adjusting it, one turn on the screw seemed to have so much more adjustment on the main than the dipped!
    VAG-COM tells me my lights are incorrectly adjusted now but they are perfect, I'm just worried that at the next service Audi will fiddle again!!!
