S3 handling problem - suspected anti-roll bar "insert" + shocks
Discussion in 'A3/S3 Forum (8L Chassis)' started by dpeilow, Jan 11, 2008.
  1. dpeilow
    dpeilow Member
    May 24, 2003
    95
    Hi,
    After carrying what was probably too heavy a load a while back (don't ask) my car hasn't been handling right since. There has been too much body roll on bumpy roads and it hasn't been tight going around corners.
    So I took it into Fontains to get it checked out and just had a phone call to say both rear shocks need replacing (£250) and also the anti roll bar "inserts" are cracked and also need replacing (another £250 fitted...)
    That last price seems a bit steep. I'm presuming they are talking about arb bushes. What else is there that could be costing this much?
    Dave
  2. Advert Guest Advertisement
  3. Defratos
    Defratos You’re Dethpicable!!
    May 26, 2004
    2,232
    The arb bushes would not be £250, they're more like £30-£40 for the nuespeed ones. As for a new arb then they're around £250, but why do your rear shocks need replacing?
  4. Aky
    Aky Aky
    Nov 21, 2006
    1,512
    sounds like a great excuse to sort out the handling with some decent suspension components!
  5. claudefrog
    claudefrog Member
    Dec 13, 2006
    372
    you need to stop picking up fat burds ;) lol
    rite.. I would take the car straight back from the dealers, order up some shocks from your local motor factors.. approx £100 will see 2 shocks.. I just had a quick check on the Eurocarparts.com website.. and they come up with
    REAR SHOCK ABSORBER AUDI TT COUPE QUATTRO -12.99
    Upto Cha 8NY-120000 £51.84
    A garage will charge you max 1 hours labour to fit them.
    Also.. ARB bushes should be about £25 - £30 to get sorted
  6. dpeilow
    dpeilow Member
    May 24, 2003
    95
    Thanks for the info
    I spoke to the garage again yesterday afternoon. They are saying it is in fact the whole ARB that needs replacing. They said this is £50 plus two hours labour.
    Given that they are doing the shocks at the same time, this seems a bit high for the labour time to me.
