[ QUOTE ]
ScotSTHREE said:
when you say oppossite lock, do you mean when the back goes out I take it? If so, HOW!? Mine refuses! Unless the weather is real bad.
[/ QUOTE ]
Yeah, the back hangs out proportionally to the front.
To do this well, and safely, you need 3 things (in my opinion)
1. A well sorted front end with lots more grip than standard and perfectly set up toe, camber, castor and tyre pressure settings.
2. A rear end set up to have proportionally less grip than the front be this from suspension angle changes or tyre pressures.
3. Lots of torque!
Once you have the front end keyed to your chosen line, you load it up hard by turning in quickly, yet smoothly and progressively...just as you unleash max boost / torque. The front end needs to stick...the Haldex dumps the torque to the rear juast at it hits full boost (an aggressive re-map helps here too). As this happens the rear power oversteers and slides out under power...then the Haldex will shuffle some torque back to the front, at which point you wind on some opposite lock, hold the throttle wide open, and powwer slide through the bends.
Not easy...but once completed with precision and panache, elevates you to driving demi-God status (in your own mind anyway!) /ubbthreads/images/graemlins/laugh.gif
It can be done...but the majority of S3s I've driven aren't well enough set up to allow it easily and safely.
You really do need a well sorted chassis to make it happen sweetly.
I wouldn't really try it in the wet...I've had mine bite back. Not pleasant.
