S3 Gearbox problem - Breakdown
Alex C Feb 24, 2011
  1. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,297
    373
    OK,
    I was driving along the local bypass in fifth or sixth gear (cant remember), when I come towards the end of the bypass i attempt to change down gear into 2nd. I pull the stick out of fifth/sixth and go to stick it into 2nd. So i try to push it across to 2nd, the stick didnt even want to push over to second, so i cruise upto the roundabout with my foot on the clutch thinking im stuck in neutral. But then i realise that despite the stick travelling in and out of 3rd, 4th, 5th and 6th the box is still stuck in whatever gear i was in when i was on the bypass (5th or 6th).
    The car has been recovered to my carpark at work and will be taken to the garage tomorrow. I would just like some idea of what it might be. I am guessing the gearbox has gone??
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    It could well be just the linkage on the gearbox one of them may have come out of the cup.....thread on here a while back with the same....
  3. s3_kev
    s3_kev Stage2'd!!!!!!
    2,002
    23
    there is a rivet on the gear selector that fails never seen it myself or experienced one so not sure on the failure but could be this?
  4. Alex C
    3,297
    373
    I had a look at the gear linkage, the cables on the selector that sits on the top of the box look fine, i gave it a wiggle and a stranger said it was all moving about, so its all connected... :(
  5. s3_kev
    2,002
    23
    will move up top but the rivet will be below where your looking so may still be your fault
  6. s3dave
    10,110
    736
    I would not have thought it was anything sinister mate, cold light of day may make you smile.....its not a siezed box or it would have been like throwing an anchor out.....
  7. Alex C
    3,297
    373
    mmm ok, maybe my fault? so i may have broken it? I didnt rip it out and go to slam into 2nd but if it is this then is this a relatively simple fix?
    No it wasnt like an anchor being thrown out, it was just stuck in gear, thanks for that, its made me feel better
  8. sportstractor
    sportstractor Chugger
    2,709
    yeah i think the same, Anything internal and it would of been making all kinds of crushing noises etc. Linkage sounds the most likely problem
  9. s3dave
    10,110
    736
    If it is that maybe upgrade to a short shifter.....
  10. Dani_B19
    9,380
    402
    I'm thinking its the selector fork thats f**k like in animals when his went last year, gearbox out jobi if it is im affraid :(. Hope it aint mate.
  11. <tuffty/>
    21,869
    4,198
  12. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
  13. Alex C
    3,297
    373
    ok, sh:t, I've have had a look at the sticker in the spare wheel well, i see the codes EUK and DQB, is the gearbox code DQB? In which case do i have to match this code?
  14. Dane
    4,086
    182
    My AMK gearbox was a DQB and I replaced it with a DQB box, I'm not sure whether you have to replace like for like but I did just incase.
    I think my box was from a TT
  15. Alex C
    3,297
    373
    how much did the replacement gearbox cost you?
  16. Dane
    4,086
    182
    Hmm I think it was £450, there were others around for a lot less but this one came with a three month warranty and next day delivery.
    If you do have to replace the box it's worth using the sensors that you know work from your old box, a 3mm split wire on the reverse switch left me without a speedo and a fuel gauge that was all over the place and cost me a Vehicle Speed Sensor (not cheap).
  17. Alex C
    3,297
    373
    As suspected it looks like it is the 5/6th selector fork thats given up the ghost, found some pictures which helped me
    So its the top selector on the left gear set in the first photo thats broken, top right selector fork in the 2nd photo. Will they have to take all of the shafts out in order to fix the selector fork? I am guessing they will have to take the whole lot apart in order to replace the rivets on the final drive-differential?
    [​IMG] [​IMG]
  18. Alex C
    3,297
    373
  19. 666markyboy
    666markyboy Well-Known Member
    1,240
    60
    Sorry to jump on this thread but Regarding that dodgy rivet in the diff ! is it possible to upgrade this without taking the box out ???? surely you can remove the diff with the box in the car ???
  20. TheButtonz
    TheButtonz Member
    97
    Something really cool about those pictures... just sayin'
    Sorry to hear about the issues. :(
  21. s3dave
    10,110
    736
    Sorry to hear your woes cookstein, them pics give me a headache...lol... is black beauty on the road yet?
  22. Alex C
    3,297
    373
    No not yet Dave, she's still in the garage and the gearbox hasn't been dropped yet. The guy in the garage stuck his hand in there and pulled the fork out, fork'n thing! He says it will be early next week until he gets the gearbox off. He has just come back from a holiday and has a backlog of jobs.
    I have have had a trawl through the big book labeled WWW. and i have found that this is quite a common problem with the O2M, i think i found one instance where some guy had had it happen to him three times! But to be honest I don't understand why this happens, surely the only stress the selector fork experiences is the force you put it under moving the gear stick, and i'm no He-man.
    Expensive times ahead me thinks. I think the current plan is to get it off and rebuild it. For a laugh he got a quote for a new gear box which was well over £3000. Also whilst its off it would be silly not to do the clutch; and flywheel if needs be.
    Ive also got some Brembs and Disks waiting to be strapped on at some point
    Anyway, the silver lining to this cloud is that whilst the gear box is out it will improve access to the rear screen was pipe connection which has been leaking for months now! Happy days!
    I spent a little while on howstuffworks.com in order to understand those photos too, i am now happy with them and dont feel sick looking at them :)
  23. Alex C
    3,297
    373
    Had some spare time, think this is all correct and might be useful for someone
    Gearbox - exploded view of components
    1 - Clutch housing
    2 - Reverse shaft
    3 - Output shaft for 5th, 6th and reverse gears
    4 - Clutch slave cylinder with release bearing
    5 - Input shaft
    6 - Output shaft for 1st - 4th gear
    7 - Differential
    8 - Bevel box
    9 - Flange shaft (right-side)
    10 - Bevel gear with input shaft
    11 - Shaft bevel gear
    12 - Output flange
    13 - Speedometer sender -G22-
    14 - Flange shaft (left-side)
    15 - 2nd speed selector gear
    16 - 1st speed selector gear
    17 - 4th speed selector gear
    18 - 3rd speed selector gear
    19 - 5th speed selector gear
    20 - 6th speed selector gear (Spacer sleeve fitted in 5-speed gearbox)
    21 - Reverse selector gear
    22 - Gearbox housing
