S3 gearbox crunch/jerk
GrantP May 9, 2013
  1. GrantP
    GrantP New Member
    21
    Hi All, my car is generally jerky between gear changes (like a clunk) and 1st to 2nd is a bit crunchy (unless you change slowly). Does this sound like a clutch switch issue or gearbox issue (synchros etc)? Any help appreciated.
  2. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    535
    Does it get any better after driving for a while?
    I have a few friends all with the 6sp box that suffer from issues selecting 1st and 2nd gear- but it's a lot easier once it's been running a few miles and all the fluids have reached the correct temperatures.
  3. GrantP
    GrantP New Member
    21
    No, not really. I recently changed the gearbox oil to see if it made any difference but I don't think it has.
  4. baldyplayer99
    baldyplayer99 Member
    80
    my s3 has the same issue sometimes. i got the car checked for codes and it was a clutch switch issue
  5. GrantP
    GrantP New Member
    21
    OK thanks, for the sake of about £12 looks like it may be worth a try.
  6. baldyplayer99
    80
    let me know how it goes if you can. i havent sorted it as yet as im due out of the country in few days and will sort it after im back... cheers
  7. jezzy
    jezzy Member
    768
    Try your dog bone mount.
    When its worn its causes the above issues
  8. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,172
    214
    I have this issue.
    No fault codes stored and my dogbone is new with uprated polyurethane bushings front & rear....hmmm.
