S3 full Haldex change (How much oil ml required)
Greig300 Oct 25, 2012
  1. Greig300
    Greig300 Member
    253
    My audi S3 is due an full Haldex oil and filter change. Ive got the removal tool, filter and one 275ml tube of haldex oil. Ive got one question. How much oil does the haldex require is 275ml enough from empty? Ive seen on the internet i need 1litre or 600ml or 3 x 275ml tubes? Im unsure what i need. Any help would be excellent. Also there is a separate part of the haldex that uses diff oil? How much and what oil is required there? Thank you.
  2. Sam_
    Sam_ Down under
    3,034
    478
    I'm pretty sure it's one whole tube (if it's from VW/Audi).
    The rear diff (often confused) is 1L and gearbox is 2.6L.
    This is from memory...
  3. <tuffty/>
    20,847
    3,687
    drain when the haldex is warm, use all the oil supplied in the tube...
  4. <tuffty/>
    20,847
    3,687
    1 x tube of haldex oil (its hydraulic oil) required for the change...
    Rear diff uses 75W90 semi or fully synth gear oil... can't remember off hand the amount (1 to 1.5 ltrs springs to mind)
  5. Greig300
    Greig300 Member
    253
    Yeah yous are correct it's 1 litre in the diff and one tube 275ml for the Haldex thanks for the help will be getting done tomorrow :D
  6. dancupra225
    dancupra225 Active Member
    667
    25
    and the tool is there only one tool that can be used??
  7. The Doctor
    The Doctor Well-Known Member
    1,394
    189
    You mean the filter removal tool? If so yes, use it!
  8. Sam_
    Sam_ Down under
    3,034
    478
    A friend of mine says he just uses some adjustable pliers (the large ones) rather than the tool, seen as you're throwing the filter away anyway. I suspect the tool is easier though, just pricy for what it is. Hardly much R&D to a bent bit of metal and a ring spanner end.
