S3 full car plastidip
R34nel Aug 14, 2013
  1. R34nel
    R34nel Active Member
    323
    33
    So I'm plastidipping my black s3 white, however I'm going to go from black - gunmetal gray - white to get better coverage and a crisper white, this is being done using an earlex 3500 with standard 2.0mm tip and needle
    So here is stage one, full gray dip
    Before:
    After:[​IMG]
    white dip to come in the next week
    nezz, S3_Jacko, Lima and 1 other person like this.
  2. Jonathaan
    Jonathaan Quattro
    720
    120
    43
    Very nice job, how many litres did you use on base coat and how many you plan to use on full colour?
    Im also planning on doing my car either Matt Blue or Matt Black.
  3. AudiMafia
    AudiMafia Member
    403
    13
    Very nice, I'm planning to do this for a very long time, how many liters for 4 coats full car should be needed if you know? thanks
  4. R34nel
    323
    33
    Thanks. I used only 3 coats on there and it was around 3.5 litres (50:50 mix), I've bought 10 litres of white premix as it will need over 5 coats to give a good white even with the light gray base. if you plan to dip black then it will cover anything with 2-3 coats however you want to do more to make it hardwearing and so it will come off easier and peel in large pieces, if I was staying gray I would have given it another 2 coats probably
    S3-Sandy likes this.
  5. OVRA3
    OVRA3 Well-Known Member
    1,079
    80
    What's the deal with this stuff? Excuse my ignorance how long does it last, how does it come off and what if anything does it do to paintwork?
  6. T3KT0N1K
    T3KT0N1K Member
    104
    9
    Ouch! That thing looks so good it stings my eyes!
    What's this plastidip you speak of and how much does it cost to get done?
  7. R34nel
    323
    33
    I think if you bought 5 litres if premix it would be enough for 4 coats but it depends on the car size and how heavily you spray it on, basically in gray I did 3 full coats then after it was dry I peeled a full rear quarter (I messed up a bit whilst peeling overspray) and redid the three coats on this area and I've still a little left out of the 5 litres
  8. R34nel
    323
    33
    Okay, according to the vast community of the web it can last years if looked after, it will literally peel of almost like a rubbery vinyl wrap and provided you use the correct thinners will leave your paintwork perfect underneath, essentially it sprays on like paint ( only more forgiving) and dries like rubber, there's many areas you don't need to mask whilst spraying ( lights, windows etc) then just peel it off when dry, if you put enough on then it will come away in one large sheet
    JudderMan likes this.
  9. OVRA3
    1,079
    80
    That's pretty cool, so how long did the prep and the spray take then? Do you have to just mask or take bits off? Looking at the front of yours looks like you got right in where the grills are etc.. Is this something anyone can do or does it take skills and practice?
  10. R34nel
    323
    33
    dip costs around 70 notes for 5 litres depending on where you buy and if you mix yourself or buy premix, but then you need a sprayer etc, the earlex 3500 is highly regarded for plastidip and cost £80 from Argos
  11. R34nel
    323
    33
    I did mask off the fog light grills however the right one came exposed part way through :0 I haven't got round to picking it off the honeycomb yet lol! the masking probably took an hour ( I'm rubbish at it) and the spraying took only 5 mins a coat, getting the overspray off took a while because if its not thick it won't peel, you have to rub the speckley bits off with a cloth
  12. turbonutz
    turbonutz Active Member
    421
    61
    hmmmm tempting, you get a type of lacqure for it so it dont chip as easy? because i can imagine stone chip central with it, also what about waxing etc, does this wear it?
  13. LEE69
    LEE69 07 170 DSG Team Dolphin Grey Audi A3
    2,140
    374
    I like it in primer :)
    JamesS4cab likes this.
  14. R34nel
    323
    33
    well apparently it doesn't stone chip, because it's like rubber they bounce off, I hear people use clear plastidip as protection for there front end, besides if it did chip you could just peel it off say the bonnet and spray it again, also yes it does look like primer lol
  15. OVRA3
    1,079
    80
    Certainly looks good! Well impressed
  16. OVRA3
    1,079
    80
    You won't however be able to post in the reflection thread :p
    nezz likes this.
  17. Jtaylor
    Jtaylor Active Member
    165
    56
    How do you get bird **** off?
  18. R34nel
    323
    33
    You an get glossifier to spray over it to give a shine although I didn't know there was a reflection thread! An well I've still got some of these pics
  19. R34nel
    323
    33
    Wipe it off, wash it off whatever you usually would do
  20. Jtaylor
    165
    56
    will it not damage the plastidip?
    It looks pretty cool, hats off to you.
  21. Zak0123
    Zak0123 Active Member
    539
    73
    So excited about this! Maybe matte neon blue instead of white? :jump:
  22. PiranhaMan
    PiranhaMan Member
    95
    this will give everyone an idea of how this stuff works... looks really easy
  23. PiranhaMan
    PiranhaMan Member
    95
    this one shows you how to remove it
  24. s3_sid
    s3_sid Active Member
    368
    35
    i would make sure you have a perfect car no paint damage ect as i had a mate who has his fabia done and dident like it pulled it off and it pretty much ruined the lacquer, pulled big bits off !
  25. turbonutz
    421
    61
    I
    Ya can pop the fog light grills out easy mate
  26. R34nel
    323
    33
    Mine is in tidy condition
  27. R34nel
    323
    33
    Can I? how do they come out?
  28. AudiMafia
    AudiMafia Member
    403
    13
    R34nel, where did you buy yours? plastidip.co.uk is always out of stock in Blue and the price for 5 liters is £80.
  29. R34nel
    323
    33
    Matt-pack.co.uk
    There's lots of advise on there and the prices are better than plastidip uk.
    It's all genuine stuff and they also spray cars them selfs if you prefer although it will cost a bit more than doing it yourself.
  30. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Team Akoya TDi saloon Audi S8
    15,161
    1,121
    It does chip.
    Mine chipped, it survived very well but I did have 1 little bit removed due to a stone but I healed it with some thinners and it was fine.
    I would not buy premix dip. I'd rather mix it myself. You get more mix for your money.
    10 litres of premix dip is about £160. mix it your self and its only £120.
  31. AudiMafia
    AudiMafia Member
    403
    13
    That's what I was thinking, I bought 5ltr of blue and 5ltr of thinner to have it 50/50, just to have a bit of extra in case.
  32. R34nel
    323
    33
    it's 140 for 10 Ltrs premix from mattpack
    So yeah it's £20 cheaper To mix yourself, however I just like it to be hassle free
    Yolo_8p3 likes this.
  33. R34nel
    323
    33
    With regards chipping, depends how thick it is I guess, mine will have 7-10 coats when finished, I can't see a stone chipping it
  34. turbonutz
    421
    61
    Yeh mate the foggies just clip out with a short sharp tug. Very easy dont be scared to tug them lol
  35. R34nel
    323
    33
    so I tug them from the front? will it break any clips or owt?
  36. Big Pumpa
    Big Pumpa Member
    135
    Looks tidy... nice one
  37. turbonutz
    421
    61
    No clips no damage. There's a cover behind frony grill that you can wedge off too to scree the fog light off but ya can just peel ya plasti dip off thst or quickly cover it I would imagine. Does seem too simple to pop out but some how they dont with driving about ha.
  38. Tomwebb
    Tomwebb A3 2.0 tdi s line 170
    60
    This is the first time ive even seen or heard about plasti dipping... AMAZING! One day my car will change colour!
  39. s3facelift09
    s3facelift09 Member
    244
    23
    That's the general idea to change the color of a car in a day without a lot of fuss. That was the idea, but in my honest opinion I think that plasti deep is not for a car like an S3, or any other expensive car. R34nel can you put some more detailed pictures of the door knobs, edges of the doors etc? I'm from Croatia, and 2 months ago a guy that has an RS6 decided to plasti dip his car. The end result was a total disappointment, and I'll give you a link to the gallery of photos so that you can see how they wrecked the car.. The best people in Croatia (with years of experience and background)were involved in this, they did the work in perfect condition (chamber), but the end result was horrible, here's the link to the gallery..
    https://www.facebook.com/media/set/?set=a.468288349932647.1073741838.117238228370996&type=3
    They said the problem was in the stuff, it's just not good enough. It could be good for cheap cars and owners who don't care much. But for more expensive cars like an S3 or RS6 it's literally light years away from a quality paint it should be..and like they say it is.
  40. coreythorny
    coreythorny Active Member
    452
    73
    We want updates! Been thinking about doing this myself, torn between blue, green, orange or yellow!
