S3 Front Suspension Diagram/Schematic please
jonS3 Jan 5, 2008
  1. jonS3
    jonS3 Member
    719
    Hi,
    does anyone have a Schematic or Diagram for the front suspension set-up of an S3 (prefacelift if it makes any difference)
    cheers
    Jon
  2. jcs356
    jcs356 Brum brum
    2,734
    70
    You could try www.vagcat.com - free to register. That might answer your question.
  3. abdus
    abdus Top Gear VCDS Map User
    1,827
  4. abdus
    1,827
    track control arm / front / quattro
    suspension / wheel bearing housing / track control arm / front / quattro:
    / AQA,AJQ; S3:APY,AMK, AUL 1 1J0407151B
    track control arm
    / quattro (1) 8N0407151D
    track control arm / also use:
    left >>8L-Y-117500 8N0 407 152 D / S3 (1) 8N0407152D
    right >>8L-Y-117500 8N0 407 151 D / S3 2 1J0407175
    lock plate
    / quattro 3 1J0407181
    bonded rubber mounting
    rear / quattro 3 1J0407181
    bonded rubber mounting / F >> 8L-Y-117 500*
    rear / S3 (3) 8N0407181B
    bonded rubber mounting / F 8L-Y-117 501>>*
    rear / S3 4 357407182
    front / quattro 4 357407182
    front / S3 (4) 8N0407182A
    front / S3 5 N 90484003
    hexagonal head bolt
    M12X1,5X82 / 6 N 10262201
    hexagon head bolt c/w shoulder
    BM12X1,5X70 / 7 N 0150814
    hexagon nut, shouldered
    M12X1,5 / 8A 1J0407255AH
    left / quattro (8A) 1J0407256AH
    right / quattro (8A) 8N0407255E
    left / S3 (8A) 8N0407256E
    right / S3 9 N 10207803
    hexagonal head bolt
    M12X1,5X78 / 10 N 10106402
    shouldered hex. nut, self-locking
    M12X1,5 / 11 1J0407365C
    guide joint
    left / quattro (11) 1J0407366C
    guide joint
    right / quattro 11A 8N0407365B
    guide joint
    / S3 12 N 90808801
    M12X1,5 / 13 N 10127706
    M8X26 / quattro 13A N 10332001
    M10 / S3 14 1J0407613G
    wheel hub with rotor
    5/100 / quattro (14) 8N0407613A
    wheel hub with rotor / see workshop manual
    5/100 / S3 15 1J0411105AE
    coil spring / 1 paint mark / 2 paint marks
    violet white / quattro: PR-1GJ/J12; PR-1GF/V84; PR-G42/L29 (15) 1J0411105
    coil spring / 1 paint mark / 4 paint marks
    green blue / quattro: PR-1GJ/U38; PR-1GF/V83; PR-G42/L05 (15) 1J0411105C
    coil spring / 2 paint marks / 2 paint marks
    green blue / quattro: PR-1GJ/U39; PR-1GF/V85; PR-G42/L09 (15) 1J0411105BK
    violet pink / quattro: PR-1GJ/U71; PR-1GF/V86; PR-G42/L10 (15) 1J0411105AG
    violet yellow / quattro: PR-G42/L11 (15) 1J0411105AJ
    coil spring / for sports-type running gear / 1 paint mark / 4 paint marks
    violet yellow / quattro: PR-1GL/J22; PR-1GK/V51; PR-1GX/V87; PR-G43/L13 (15) 1J0411105BF
    coil spring / F >> 8L-Y-110 000* / for sports-type running gear / 1 paint mark / 4 paint marks
    violet green / quattro: PR-1GL/J23; PR-1GK/V52; PR-1GX/V88 (15) 1J0411105AM
    coil spring / F 8L-Y-110 001>>* / for sports-type running gear / 1 paint mark / 2 paint marks
    violet pink / quattro: PR-1GL/J23; PR-1GK/V52; PR-1GX/V88; PR-G43/L19 (15) 1J0411105BE
    coil spring / F >> 8L-Y-110 000* / for sports-type running gear / 1 paint mark / 3 paint marks
    violet green / quattro: PR-1GL/J24; PR-1GK/V53; PR-1GX/V89 (15) 1J0411105AL
    coil spring / F 8L-Y-110 001>>* / for sports-type running gear / 1 paint mark / 1 paint mark
    violet pink / quattro: PR-1GL/J24; PR-1GK/V53; PR-1GX/V89; PR-G43/L21 (15) 1J0411105CE
    coil spring / for sports-type running gear / 2 paint marks / 3 paint marks
    blue white / quattro: PR-G43/L08 (15) 1J0411105AT
    coil spring / for models with heavy duty suspension / 1 paint mark / 4 paint marks
    violet white / quattro: PR-G89/X29; PR-G89/Q29; PR-G89/L23 (15) 1J0411105AS
    coil spring / for models with heavy duty suspension / 1 paint mark / 3 paint marks
    violet white / quattro: PR-G89/X30; PR-G89/Q30; PR-G89/L22 (15) 1J0411105BH
    coil spring / for models with heavy duty suspension / 2 paint marks / 2 paint marks
    violet yellow / quattro: PR-G89/X31; PR-G89/Q31; PR-G89/L16 (15) 1J0411105BG
    coil spring / for models with heavy duty suspension / 2 paint marks / 1 paint mark
    violet yellow / quattro: PR-G89/X32; PR-G89/Q32; PR-G89/L20 (15) 1J0411105AF
    coil spring / for models with heavy duty suspension / 1 paint mark / 1 paint mark
    violet yellow / quattro: PR-G89/X33; PR-G89/Q33; PR-G89/L06 (15) 1J0411105AH
    coil spring / 1 paint mark / 3 paint marks
    violet yellow / S3: PR-1GQ/U85; PR-1GS/U85; PR-G21/L12 15 1J0411105AJ
    violet yellow / S3: PR-1GQ/U86; PR-1GS/U86; PR-G21/L13 15 1J0411105BF
    coil spring / F >> 8L-Y-110 000* / 1 paint mark / 4 paint marks
    violet green / S3: PR-1GQ/U87; PR-1GS/U87 (15) 1J0411105AM
    coil spring / F 8L-Y-110 001>>* / 1 paint mark / 2 paint marks
    violet pink / S3: PR-1GQ/U87; PR-1GS/U87; PR-G21/L19 (15) 1J0411105BE
    coil spring / F >> 8L-Y-110 000* / 1 paint mark / 3 paint marks
    violet green / S3: PR-1GQ/U88; PR-1GS/U88 (15) 1J0411105AL
    coil spring / F 8L-Y-110 001>>* / 1 paint mark / 1 paint mark
    violet pink / S3: PR-1GQ/U88; PR-1GS/U88; PR-G21/L21 16 1J0411305B
    stabilizer / F >> 8L-X-140 000*
    21MM / PR-0AL: quattro (16A) 1J0411305AD
    stabilizer / also use:
    19MM 1J0 411 413 S / PR-0AR: quattro (16A) 1J0411305AD
    19MM 1J0 411 314 S / PR-0AN:S3 17 1J0411314R
    rubber mounting / F >> 8L-X-140 000* / for stabiliser:
    19MM 1J0 411 305 B / PR-0AL: quattro 17A 1J0411314P
    rubber mounting / F 8L-X-140 001>>* / for stabiliser:
    20MM 1J0 411 305 L / PR-0AR: quattro (17A) 1J0411314P
    rubber mounting / F 8L-Y-142 001>>* / for stabiliser:
    20MM 1J0 411 305 AA / PR-0AN:S3 (17A) 1J0411314R
    rubber mounting / for stabiliser:
    19MM 8N0 411 305 A 1J0 411 305 G 1J0 411 305 AA / PR-0AN:S3 (17A) 1J0411314S
    17MM 1J0 411 305 AD / PR-0AN:S3 18 1J0411315C
    connecting link / F >> 8L-X-140 000*
    / PR-0AL: quattro 18A 1J0411315D
    connecting link / F 8L-X-140 001>>*
    left / PR-0AR: quattro (18A) 1J0411316D
    right / PR-0AR: quattro 18A 1J0411315D
    connecting link
    left / PR-0AN:S3 (18A) 1J0411316D
    connecting link
    right / PR-0AN:S3 19 1J0411323A
    bearing pin / F >> 8L-X-140 000*
    / PR-0AL: quattro 20 1J0411325B
    bearing tube / F >> 8L-X-140 000*
    / PR-0AL: quattro 21 1J0411327
    / PR-0AL: quattro 22 1J0411336D
    pipe clip / F >> 8L-Y-045 000*
    / PR-0AR,0AL: quattro 22 1J0411336D
    pipe clip / F 8L-Y-045 001>>*
    / PR-0AR/G0G: quattro 22 1J0411336D
    / PR-0AR/G0L, G0N: quattro 22A 8N0411335A
    / PR-0AR/G0L, G0N: quattro 22 1J0411336D
    / PR-0AN:S3 22 1J0411336D
    / PR-0AN:S3 22A 8N0411335A
    / PR-0AN:S3 23 N 10101603
    hexagonal head bolt
    M8X18 / 24 1J0412249
    axial grooved ball bearing
    / 25 1H0412303B
    rubber stop for shock absorber
    / PR-1GF,1GJ, G42 25 1H0412303B
    rubber stop for shock absorber / for models with heavy duty suspension
    / PR-G89 25 1J0412303
    / PR-1GK,1GL, 1GX,1GQ,1GS, G43 26 1J0412319C
    limit stop
    / 27 N 90353603
    hexagon nut, self-locking
    AM14X1,5 / 28 1J0412331C
    suspension strut storage
    / 29 357412341A
    spring disc
    upper / 30 1H0412365A
    threaded bush
    M14X1,5 / 31 1J0413031P
    shock absorber / F >> 8L-X-140 000*
    / PR-1GJ: quattro 31A 1J0413031BK
    shock absorber / F 8L-X-140 001>>*
    / PR-1GF,G42: quattro (31) 1J0413031R
    / PR-1GK,1GL: quattro (31A) 1J0413031BL
    shock absorber / F 8L-X-140 001>> 8L-Y-129 000* / for sports-type running gear
    / PR-1GX: quattro (31A) 1J0413031CQ
    shock absorber / F 8L-Y-129 001>>* / for sports-type running gear
    / PR-G43: quattro (31A) 1J0413031DB
    / PR-G89: quattro 31A 8N0413031D
    shock absorber / F >> 8L-X-062 000*
    / PR-1GQ,1GS: S3 (31A) 8N0413031H
    shock absorber / F 8L-X-062 001>> 8L-Y-129 000*
    / PR-1GQ,1GS: S3 (31A) 8N0413031G
    / PR-G21:S3 32 357413175A
    bellows
    / (33) N 0151002
    hexagonal nut / F >> 8L-X-140 000*
    M10 / PR-0AL: quattro 33A N 0150814
    hexagon nut, shouldered / F 8L-X-140 001>>*
    M12X1,5 / PR-0AR: quattro 33A N 0150814
    M12X1,5 / PR-0AN:S3 34 N 10417601
    hexagonal head bolt / F >> 8L-X-140 000*
    M10X50 / PR-0AL: quattro 35 N 90663201
    securing ring
    74X2 / 36 N 90587602
    12 point socket shouldered nut self-locking
    M20X1,5 / 37 N 90321302
    M12X1,5 / 38 1J0498625
    wheel bearing with mounting parts / comprising:
    / 40 1J0412311
    distance piece / for models with heavy duty suspension
    / PR-G89 41 1H0412365A
    threaded bush
    M14X1,5 / 42 1J0412359
    cap / F 8L-X-042 001>>*
    / 43 G 052735A2
  5. abdus
    1,827
    :lmfao:
    hope this helps :)
  6. jonS3
    jonS3 Member
    719
    it certainly does, thanks
    I'm looking to change my top mounts, and want to see what else is worth changing at the same time
    i've come up with top mount, bearing, and bump stops so far...
