S3 Front speakers
S3Steve Aug 4, 2007
  1. S3Steve
    S3Steve Active Member
    1,621
    19
    Due to the shallow mounting depth for the front speakers in the S3, choices are quite limited, i was wondering what speakers people who have already upgraded have used?
  2. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    quite a few companies do shallow fit speakers
    kenwood,alpine,jbl,
    the one id reccomend is the rainbow cs but it does involve a little bit of messing around to fit them
    other than that id reccomend focal access which should fit straight in no messing
    there are some others such as dynaudio but these cost perhaps 3 times that of the others which may or may not be above your budget
    there is another guy on the forum named andymac who is very knowledgable on the s3 whom may be able to give you some more options
  3. S3Steve
    1,621
    19
    Thanks for you reply, ive been told focal do some slim speakers that work well in the S3. I was hoping some S3/A3 owners out there had some experience, as ive heard some speakers that sound better in some cars than others, due to speaker location.
  4. Emmo
    Emmo Member
    232
    14
    I've fitted alpine 5.25" speakers in the front door of my a3.
    you will need spacers to make them fit.
    you will not really get any bass from the front speakers as there is nothing solid to fix the speakers against, the speakers are actually fitted on the door card. i wouldnt worry too much about the bass if your fitting a sub.
    I changed all my speakers and am running them off a 4 channel amplifier, and have also fitted a 12" sub in a sealed box in the boot.
    Ive fitted the 2 amps in the space where the audi sub used to be, so they dont take up any of my boot space and the wiring is hidden away nicely.
  5. edward_harris
    edward_harris s3 gone now a shiney red evo 6
    1,061
    i had focal ployglass 5.25 slim in mine, the tweeters sound amazing but they really dont kick out ANY bass at all! now ive had these focal k2p fitted into an aftermarket collar sound amazing
  6. dualmono21
    1,138
    to get good upfront midbass from the focals you would have to go active
    unfortunatly focals passives air on the side of caution as to the level of midbass they let through
    but they can do it with solid enough mountings
  7. S3Steve
    1,621
    19
    I was trying to avoid having to fit custom enclosures to the front doors, but if thats what it takes to get the sound quality right i might have to bite the bullet and just do it.
    Did you make those enclosures ED, or did you buy them from somewhere?
