S3 front pads - quick reply needed please!
Staz Dec 30, 2008
  1. Staz
    Staz is a retronaut Moderator VCDS Map User
    6,206
    67
    My S3 is in the 'shop for them to look at some brake squeal.
    I won't bore you with the details but they're offering to change the front pads for half the normal price of £434 as a gesture of goodwill.
    Is this the going rate for changing pads from an Audi dealership?!
    How much would it cost from a normal garage roughly?
    And how much are the pads on their own if I were to do them myself?
    There're still plenty of miles left on the pads but half price always sounds good to me!
    Thanks in advance.
    EDIT: Just phoned York Audi and they said £125!!! I think the man at Bedford has made a mistake somewhere!!
    You can ignore this thread now lol
  2. RobinA3
    RobinA3 Well-Known Member
    1,828
    47
    Pads are sooooooooooooooooooooooooooo easy to change, i would say on the driveway its a 30mins job max!
  3. Staz
    6,206
    67
    Okiedokie then! I have changed pads discs and drums on my old fiesta but if they're as easy as that was then I'll do it myself. I work in a big workshop anyway.
    Cheers!
  4. RobinA3
    1,828
    47
    yeah the principle is the same as your old fiesta but on bigger proportions!
  5. kaz219
    kaz219 Active Member
    1,808
    They're easy mate - Took me 30mins to do my S3 pads :D
  6. edition
    edition Active Member
    1,426
    And how much are the pads then? O.E.M ones..
    Also how long do the discs last? mine has done 32k and pads look like they have a fair bit left still.... Will it need both discs and pads when the pads have gone?
  7. DiscoPanda
    DiscoPanda Member
    159
    Discs should last for years and years. No need to replace them so soon. You go through many pairs of pads before the discs need replaced. Just make sure you don't run down the pads so much that the metal starts to rub on the discs - THATS when you need new discs! (as I found to my expense :( )
    Just call Audi and ask how much pads are. Or buy some aftermarket ones from here http://www.ebcbrakesdirect.com/
    And to the OP with squealing brakes, take them off, and make sure they are properly greased before refitting them. Feck paying Audi any money to replace good pads.
  8. Staz
    6,206
    67
    It turns out that they wanted to change the discs as well as the pads, hence the £430!
    I said no way of course.
  9. kaz219
    1,808
    OEM pads are £60+VAT IIRC.
    I got mintex on mine and they were around £38ish.
  10. buffalino
    buffalino LIVING THE GOOD LIFE
    77
    any good pads out there ,, that are not from audi
  11. DiscoPanda
    DiscoPanda Member
    159
    :icon_thumright:
  12. Young un
    Young un Member
    101
    Just wondering what sort of brake squeal did you experience?
    I experience an intermittent brake squeal from the front brakes. It is most noticeable when im completely slowing down. If I take pressure off brake pedal and allow the car to coast then the squeal stops. I haven't noticed the squeal whilst driving and gently dab the brakes then continue (without actually stopping)
    Audi have already investigated and assured me that they found nothing wrong and they suspect its the cold weather and road salt at this time of year. I dont believe that cos it has never happened on previous Audi vehicle and certainly doesnt occur on girlfriends TTs.
    Only done 7.5k from new and brakes havent been abused so I dont know what the problem is.
    Does this sound similar to your squeal?
  13. Staz
    6,206
    67
    My squeal only comes under light braking.
    Once I told them it was the rear brakes that were the problem (the service woman hadn't written that down) they said they couldn't find a problem. But they cleaned it all up before putting it back together just in case.
    It's still doing it though.
  14. Young un
    Young un Member
    101
    Yeah mine is also under light braking, literally as Im slowing down from 15mph to stand still. However, if I let the car roll to complete stand still (instead of applying brakes) there is NO squeal. Im puzzled and its annoying
  15. Khufu
    Khufu Well-Known Member
    5,704
    31
    Nearly choked on that price LOL. If you really needed disc on an 08 plate I'd be questioning your driving style LOL
  16. Staz
    6,206
    67
    If you don't apply the brakes you won't get any squeal, I don't understand why you're confused by that.
    Mine is most obvious when I'm in a carpark for example and I'm using my brakes to gently adjust my speed rather than just stopping, if you get what I mean.
    If I get the chance I'm going to strip them down myself when I'm back at work and apply plenty of copper slip.
