S3 front brake calipers and discs on A3 2.0TDi
SimonAshley Nov 13, 2009
  1. NHN
    29,328
    1,708
    You change your mind more than a mexican whore changes her knickers mate, lol, thats if she even wears them I guess, lol
  2. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
    Waste of cash. You'd be better just buying some good pads and a set of Goodridge brake lines. On a car like this there's no real benefit going for "performance" discs.
    The S3 setup works really well for a factory setup and would be a massive improvement over the 312mm discs you've got already, and if you buy the calipers for the right money is an inexpensive upgrade.
  3. NHN
    29,328
    1,708
    Couldnt agree more with what you just said.
    Did you use the MK5 lines from Goodridge as 8P isnt listed & they replied saying none for that model, but obviously MK5 3.2 is same as 3.2 8P so must fit.
    If so, do you have the part numbers to hand please.
  4. V6Pete
    1,491
    Yes they were the Mk5 4WD lines which were a perfect fit. Part no was SVW0615-4C for the kit with stainless fittings I went for.
  5. NHN
    29,328
    1,708
    Thanks, its is appreciated.
  6. N8
    17,163
    718
    Good find Pete, can't wait to get my brakes on now....
  7. A3_Rider
    A3_Rider Well-Known Member
    723
    255
    The 312mm discs are the ones I wanted to get from that site as I need new discs (still using the same ones I got when new).
    I'm thinking; combine the discs with the pads and brakelines you said = worth it?
  8. PTTM
    PTTM Pedal to the Metal!!!
    85
    Gents (Nige + Nath) your expertise on brakes is required again!
    I have a 2006 a3 2.0tdi 3dr and need the entire brake setup replacing as im at 101,000 and have only replaced the pads since buying 3 years ago at 16,000 miles.
    You have mentioned above that the R32 / S3 / 3.2 brake setups are 'almost' identical.
    So for me to get that setup and get a garage to fit them labour only I would need to provide them with the following:
    - Brake discs
    - Pads
    - Calipers
    - Carriers
    - Brake Lines
    Where would you recommend I start looking and would I just ask if they have the parts for the R32 / S3 / 3.2 braking system?
    Do I need the setup from the same year as my car (2006)?
    Any other things I should take into consideration?
    Thanks again chaps!
  9. H8
    H8 New Member
    hi all, am looking at a set of s3 brakes set on ebay now and i was wondering if it will fit on my Mk 2 skoda octavia VRS.. and also would anyone know if i can upgrade my turbo to the s3 - would the pipes be the same?? many thanks
  10. SimonAshley
    SimonAshley Member
    87
    Finally fitted my S3 brakes
    Before:
    During:
    After:
    And today after a clean pics all round as I haven’t put any up
  11. Hawkes
    Hawkes Member
    57
    anyone know if the s3 brakes fit under 17s?
  12. SimonAshley
    SimonAshley Member
    87
    As far as I am aware they wont
  13. warrenlord
    warrenlord Member
    771
    15
    Yep they do! I've got a complete hub set up, dropped it in and fitted
  14. jungleman
    jungleman Well-Known Member
    2,035
    42
    +1 for them fitting under 17's, the 3.2 has the same brakes and that came with 17's as standard from the factory
  15. Johnny Bravo
    Johnny Bravo 6+1 Gears Bronze Supporter Audi A3
    898
    69
    It depend on the rims you want to use. On some 17"s they might not work. I have a friend who recently made the conversion to S3 front brakes and they fit. I'm also going to do this upgrade.
    The distance between the caliper and the rim is VERY small. If the rim has spokes that are inclined, they may hit the caliper.
    These rims will fit:
  16. Hawkes
    Hawkes Member
    57
    cool cuz they're the wheels I have and I have 10mm spacers on the fron anyway :thumbsup:
  17. JamS3
    JamS3 Active Member
    2,258
    20
    Ive a full set of 8P facelift S3 brakes for sale if anyone is looking for a set, come complete with calipers, pads, discs and brake lines. PM me if interested.
