S3, flat spot when pulling away!
DPM Jun 11, 2006
  1. DPM
    DPM Site Sponsor Site Sponsor
    5,092
    227
    Audi S3... Flat spot in first gear pulling away, anybody experienced it on there's?
  2. Olly_K
    Olly_K Administrator
    2,678
    in 1st gear ? what kind of rpms is it at ?
    is it only 1st gear ?
  3. DPM
    5,092
    227
    Just first gear pulling away, just as the revs start climbing!
  4. leecs3
    leecs3 thinking about stuff
    604
    mines suffering with that at the minute too. Wonder if its the hot weather?
  5. DPM
    5,092
    227
    Don't know, i was thinking it might of been something to do with the injectors?!
  6. leecs3
    604
    mines ok once it comes on boost. L200 is the same and the TDI VW.
  7. monkeytrousers
    monkeytrousers Member
    371
    Does the car seem to lose power completely for a fraction of a second, and thus make you lurch?
    Mine does this sometimes ... but I'm convinced it's the traction control (even though the dashboard light doesn't always come on).
    Try it with traction control turned off ... in my case it cured it, so if I want a guaranteed fast start, I flick the traction off for the launch.
  8. Olly_K
    2,678
    if it was the injectors you'd have serious performance problems in all gears
  9. bioharry
    bioharry Member
    76
    Try turning the Air con off. Simple as that.
    Its the extra load that it puts on the engine and at low rpm's the engine struggles.
  10. DPM
    5,092
    227
    Another option has been brought in now... could be a dodgy MAF?!
  11. rich1068
    rich1068 Member
    674
    Service your Forge DV and remove, clean, refit and reset your throttle body.
    You'll be suprised.
  12. DPM
    5,092
    227
    how do you reset the throttle body? the dv is brand new!
  13. neil.c
    neil.c Senior
    568
    It could just be that the turbo is not on boost as you pull off
  14. rich1068
    rich1068 Member
    674
    Ideally it should be off the car (5 min job) then give it all a good spray with carb cleaner and a wipe round to get all the gunk out. Refit it and then reset with Vag-com. This should all be done with the engine cold.
    If you're not happy doing this yourself then a specialist will charge you no more than half an hour. Don't listen to them if they say it's unnecessary.
  15. DPM
    5,092
    227
    I don't know! Just gunna have to keep the revs high if i want a quick get away!
  16. leecs3
    604
    got a new MAF for mine today. Fitting it tonight and hoping it for an improvement in the cars hit and miss performance.
  17. DPM
    5,092
    227
    Tell me how you get on Lee mate!
  18. leecs3
    604
    fitted it. Not been able to take it for a spin yet but starting the car and pressing the throttle it's rev'ing much smoother and tickover seems more even. Got high hopes. Bought the MAF from ECP for £76+Vat. You also have to pay a surcharge of £25+vat. Its a Bosch unit too which is good, the guys at Dubsport told me to make sure I get a Bosch replacement as the Pierburg version is poor.
  19. DPM
    5,092
    227
    Once you've took it for a :racer: tell me the outcome bud!
  20. leecs3
    604
    its fixed. Sooo much better, the throttle response is much sharper, the power delivery is much smoother and the cars quicker in the lower gears. Car feels right.
  21. DPM
    5,092
    227
    Cheers Lee! Had it on my mates vag.com yesterday and it brought up to fault codes, the boost pressure control valve and the MAF. It's in at the local stealership tomorrow to get sorted... under warranty i hope!
  22. leecs3
    604
    Same two problems i had.
