S3 Fitting Turbo
MarkyS3 Sep 24, 2012
  1. MarkyS3
    MarkyS3 Member
    192
    Think the garage has found my lack of boost and blowing exhaust, the turbo is hanging off the manifold....
    Can they take it off and refit it without taking manifold off?
  2. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    hi mate i dont think its a nice job, i was told its easier to take the head off, or in my case im gonna take the engine out to replace my turbo
  3. jezzy
    jezzy Member
    768
    i have just changed my manifold to xs power, and i dont see how the turbo can come out without taking the mani off.
    if your turbo is hanging off, why not just bolt it back up?
    its only three bolts and quite easy to bolt on to a standard manifold, its no easy on a xs power one.
    i have a spare cast audi mani with no cracks if needed just pm me
  4. MarkyS3
    MarkyS3 Member
    192
    Ok mate i will speak to garage tomoz see what they say/find. It has to come off and gasket will need replacing. How much would you want for it mate? how many miles etc?
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    The turbo is easy to bolt back up to the Manni and get a new gasket in on the car...
  6. MarkyS3
    MarkyS3 Member
    192
    Thanks Dave :) will make it a tad cheaper, if thats the only place its blowing.
  7. jezzy
    jezzy Member
    768
    as above mate, try bolting the turbo back to the mani first.
    its the cheapest option.
    bolts a 2 quid each from tps or audi if i remember correctly.
    if the garage is telling you the mani has to come off, ask why they cant just bolt it back up?
    bolts sheared off? mani crack and so forth.
    and then come back and let us know otherwise it could become quite expensive.
  8. MarkyS3
    MarkyS3 Member
    192
    From what they are saying it appears there is a bolt missing on mani to head, so lets hope its not sheered or it will be head off :(
  9. Prawn
    11,370
    3,234
    You're joking right? Engine out to change a turbo? that's madness!
  10. s3dave
    10,110
    736
    They have an habit of unscrewing themselves and popping out, maybe ask them to use nordlock washers when refitting?
  11. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,183
    Some people give up too easy.
  12. phil miller
    1,211
    166
    maybe a lot of work but because I'm gonna be doing and changing other bits aswell it makes more sense for me to do it that way
  13. MarkyS3
    MarkyS3 Member
    192
    Right ive spoke to Garage exhaust blowing problem is the fact the Turbo is hanging off, this would also be why there is no boost lol
    Twice when ive booted it ive heard a pinging noise under the car like i have run over a bolt, this was probably the two turbo to manifold bolts making a run for it lol.....
    He is going to get another gasket and the bolts and try bolting it back down and fingers crossed thats it sorted, he was saying the turbo holes are threaded or something like that so if they are knackered will need a new turbo.
  14. jezzy
    jezzy Member
    768
    or a tap and die set?
  15. MarkyS3
    MarkyS3 Member
    192
    Yeh possibly, but trying to do that while its fitted to car could be impossible.
  16. 16Klappe
    5,795
    1,183
    Nordlock washers, ring bill at Badger 5. That will stop them working loose even if the threads are a little worn.
    Worked wonders on my stretched K03.
  17. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,126
    1,968
    This is what you get if you pay sub 2k for an S3,just saying
  18. MarkyS3
    MarkyS3 Member
    192
    Not really bothered, will cost £15 for bolts and gasket so still a cheap S3.
  19. Tooks
    Tooks Active Member
    753
    29
    Labours free then?!
    Its clear that your car has had some very unsympathetic owner/s, let's hope this isn't just the tip of the iceberg for you.
    At least it seems to be in better hands now!
  20. S3_OL
    S3_OL Active Member
    101
    41
    I also reccomend Nordloc washers. used them on my relentless manifold and its been fine for 2K miles.
  21. MarkyS3
    MarkyS3 Member
    192
    Yes labour is near as dammit free as im sponsored by them for my rallying.
  22. 16Klappe
    5,795
    1,183
    You say that Jason, a friend of mine paid £1000 for an immaculate 110k one owner from new pre facelift S3. The turbo smoked; he fitted a new K04 himself and has gone 11k in it since. The whole thing owes him less than £1300.
    Price means nothing when measuring the quality of a car. If it's a dog it's a dog, regardless of price. I have seen right sheds up for £3/4000.
  23. Tooks
    Tooks Active Member
    753
    29
    Interesting! What car do you rally and which events? Me and/or my mate might have got you off the startline somewhere? My mate also owns/crews one of the rescue units you'll see out and about.
    It would be good to keep a running total of what you end up spending, I can't imagine there are any S3's out there that haven't had the common faults by now, and either had them fixed or are carrying them.
    I purchased what I thought was a very good S3 for a good price earlier this year, but it has still needed circa £800 spending on it (all just parts) to get it to where it should be. I've actually spent more, but some was cosmetic work (alloy refurb etc), and not strictly necessary
    Make sure you keep your garage in beers!
  24. Lemon S3
    Lemon S3 Alex
    1,390
    41
    You can remove the turbo without taking the head off. I changed mine a few months ago by just removing the TIP and taking it out that way. Took me a little over an hour to remove and about 2 to fit.
  25. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    The genuine Borg Warner K04s come with an insert. The insert goes into the large threaded hole, and then the bolt screws into the insert.
    Chinese copies don't have these, you wind the bolt directly into the cast.
    I have seen previously the insert wind out of the casting instead of the bolt coming out of the insert. Thats a pain.
    New gasket and some new bolts and I'm sure it will be fine. Unusual for that the be the case though, normally they are impossible to undo due to heat.
    That would suggest to me it's had something done recently by an amateur...
  26. MarkyS3
    MarkyS3 Member
    192
    This car is immaculate apart from its running issues. Like showroom condition really.
    I rally a 106 Cup Car on Tarmac Events throughout South West.
    Visit MJRallying | Facebook and give us a like or MJRallying | Wix.com
