s3 fitting 18 x 9.5 all round ?????
Discussion in 'A3/S3 Forum (8L Chassis)' started by justin3779, Jun 27, 2012.
  1. justin3779
    justin3779 New Member
    Oct 9, 2009
    26
    hi folks i found a thread on here saying they might not fit but there was one for sale recently with them on and it looked perfect, i tried to contact the seller but got no reply.
    the wheels will be brand new from 3sdm and tyres will be 225/40/18s the same as the one in the pictures ( this is the one that was for sale, any help and advice will be greatly appreciated as i need this stance badly
    thanks guys
    #1 justin3779, Jun 27, 2012
  2. Advert Guest Advertisement
  3. Nogmeister
    Nogmeister Member
    Jun 12, 2012
    290
    You can get those wheels in 8.5 if 9.5 is too wide for the front mate:thumbsup:
  4. justin3779
    Oct 9, 2009
    26
    anyone ????? someone on here must of had 9.5s all round at some point or at least tried ???
  5. gareth_oau
    gareth_oau Member
    Dec 3, 2008
    228
    I'm running 8.5" on the front of mine with 5mm spacers, and the inside clearance is thinner than a cigarette paper - but I think this is partially due to the Goodyear Asym 2s I'm running (235/40/18) which have a large rim protector on them.
    The outside is within around 5mm of the guards.
    If you go 9.5" on the front you will definitely need at least 10mm spacers to give inner clearance (and not accounting for rim protectors on tyres), but this will then have the outside of the rim sitting at least 12mm outside of the guards.
    You won't be able to run it lowered
  6. liquids3
    liquids3 Member
    Jul 2, 2010
    931
    22
    You could do it,but you would need to get your arch's rolled alot,for it not to look stupid,you would get some rubbing isues but would work,what et are they?,or like someone else said get the 8.5 fronts,would look better cheeper,and wider on the rear is better stance in my book.
  7. Danio
    Danio AUDI-MANIACS.COM
    Aug 5, 2011
    214
    22
    Depends what collies will you use. My mate has got KW V3 collies and 9.5J all round ET 38 with 30mm spacers on the back and 25 on the front. And I would say not much space left between strut and the wheel.
