S3 feels slow
s3joe Jan 14, 2014
  1. s3joe
    s3joe Active Member
    581
    92
    I have not had my s3 that long but before it I had a golf gti with a stage 1 map and a s3 8l and this one does not feel anywhere near as fast as them two it revs rite up to red line but I can hear the turbo whistle from about 3.5k but just does not seem quick at all any ideas
  2. Dave-S3
    Dave-S3 Active Member
    653
    124
    43
    Possible boost leak?
  3. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,063
    572
    mine doesn't feel fast as does my friends mkv gti stage2+ but it's faster for sure. i guess it's the way the s3 put's the power down through 4wd.
    also you can check your diverter valve for splits, if you have prefacelift s3.
  4. s3joe
    s3joe Active Member
    581
    92
    I might get the dv off it and have a look at it. When is it normal to hear the turbo
    Cozza McA likes this.
  5. Marshy
    Marshy Settled in Audi RS3
    1,352
    470
    With the window down I can here my turbo whistle from approx 2500rpm
    I've been running mine for 3 months and a few weeks ago I thought it was getting slow and the turbo didn't whistle until 3500rpm it turned out my air flow meter was faulty.
    What a difference silky smooth again and turbo in from 2500rpm.
    I unplugged my air flow meter which didn't put the light on and the difference was extremely noticeable.
  6. s3joe
    s3joe Active Member
    581
    92
    I'll try that nice one mate I will try and get a maf reading as well
  7. S3Alex
    10,833
    4,830
    To be fair,the S3 8P is a pretty heavy car.
    1500kgs and 265bhp makes for a brisk,but not rapid car,and it's delivery is also pretty linear,which may result in it's feeling a bit sluggish.
  8. s3joe
    s3joe Active Member
    581
    92
    Yer I know that but I am not convinced that it's running rite if you get me
  9. S3Alex
    10,833
    4,830
    I understand.....as the others have said,boost loss may be the problem and would account for the noise,and the diverter valve is a good place to start.
  10. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    I went from Mk5 Golf Gti Stage 1 to a stock S3 and the S3 should feel at least as quick.
    If it doesn't then something is broke.
  11. s3joe
    s3joe Active Member
    581
    92
    no defo deoes not feel as quick going to get the dv off tommorrow
  12. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Get it sorted then stick a map on it.
    Good luck.:thumbsup:
    s3joe likes this.
  13. gatuno12
    gatuno12 New Member
    17
    12
    Yes it doesnt feel
    As fast as my gti mk6 stage one but certainly is faster, 0 to 62 in the golf wasnt any better than 5.6 this one is 4.8 just as the magazines tell. Remember ybou are comparing a chipped car eith an original car and also gtis have the traction issue and the torque steer issue which add drama to the feeling of speed.
  14. gatuno12
    gatuno12 New Member
    17
    12
    I have to add tat im comparing the gti with the new s3 8v .
    Chipped gtis are faster or as fast as 8p s3s
  15. s3joe
    s3joe Active Member
    581
    92
    Bit of a update I have changed the dv as it was split but now I seem to get flutter under boost any ideas on this one
  16. mjr901
    mjr901 Guest
    Tis the norm for the flutter sir.
  17. Marshy
    1,352
    470
    Usually 3rd and 4th gear approx 3500rpm the flutter is normal.
    Is that when it happens?
  18. s3joe
    s3joe Active Member
    581
    92
    Rite ok as long as I know thanks lads
  19. s3joe
    s3joe Active Member
    581
    92
    uploadfromtaptalk1389899806374.jpg I think it's split
  20. S.
    2,063
    572
    definitely :D
    how does it go now?
  21. s3joe
    s3joe Active Member
    581
    92
    Like it should STINK ha ha ha
    S3Alex and chris.vincent3 like this.
  22. S3Alex
    10,833
    4,830
    Well......that's well past it's sell-by date.
  23. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    Now get it mapped
    wuta3 and S3_Mat like this.
  24. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    And buy the MT TBE exhaust you need so you can go straight to stage 2..........
    Trust me - you wont look back.
    wuta3 likes this.
  25. RedDejavu
    RedDejavu Well-Known Member
    1,806
    337
    stage2+ dont bother with stage2 as the pump might not be enough to give you massive fuel dips between 3-5k revs
    wuta3 likes this.
  26. PaulAr
    PaulAr S3 (8P)
    4,073
    186
    This.
    Milltek TBE is a must. Makes a real difference even with just Stage 1 software.
  27. JamesS4cab
    1,191
    94
    Finally you say something worth reading..........
    :p
    PaulAr likes this.
  28. S3Alex
    10,833
    4,830
    Good point....I think Stg2+ (or Stg3 in Shark-speak) is the best overall value for the S3,and gives a lot of torque and power without excessive costs.
    wuta3 likes this.
  29. Tom5190
    Tom5190 Active Member
    318
    139
    43
    If you pull the DV out and it is split can it go back in for a few days until another comes? or do they ususally fall apart?
  30. s3joe
    s3joe Active Member
    581
    92
    No you can put them back in as long as you can put it back together
  31. S.
    2,063
    572
    must agree with you. i had stage 2 for a year and after fitting the pump it was a big difference. now the car is proper fast :D
    also if you get 2nd hand parts you can get there even cheaper.
    S3Alex likes this.
  32. JamesS4cab
    1,191
    94
    Fear not - i have offered him the necessary exhaust and i know he knows its the right thing to do. :moa:
    S. likes this.
  33. S.
    2,063
    572
    :laugh::respekt::sign_plug:
  34. JamesS4cab
    1,191
    94
    You can't blame a guy for trying......... :p
    It's not much use to me sat on the garage floor so Joe may we as well make use of it!
    S. likes this.
  35. s3joe
    s3joe Active Member
    581
    92
    I know you have offered me one but I have been ripped off so many times buying things on forums and goods not turnning up if you lived closer I would bite your hand off mate
  36. JamesS4cab
    1,191
    94
    Mate. I fully appreciate what you are saying but I am a well established member on here with over 1k posts, over 3k on vagoc and have met and dealt with a fair number of people on both forums. I know there are admin on both forums that can vouch for me. I'm not here to rip people off and there are plenty of others that have bought stuff from me with no issues. You really have nothing to worry about.
  37. Kelza
    Kelza MODERATOR Staff Member Moderator Audi RS3
    3,078
    605
    Hi joe James is a top bloke I've have bought many s3 8p parts from him and all parts arrived safe and sound :)
    s3joe and JamesS4cab like this.
  38. s3joe
    s3joe Active Member
    581
    92
    I have sent you a pm
  39. S3Alex
    10,833
    4,830
    Likewise,I'd vouch for James as well.
    Top bloke and very good to meet.
    Kelza and JamesS4cab like this.
  40. JamesS4cab
    1,191
    94
    Thanks gents. Appreciate it.
    Kelza likes this.
