s3 fault codes 17705?what problems this cause?
jarvis**turbo** Jan 21, 2008
  1. jarvis**turbo**
    jarvis**turbo** Member
    58
    run vag-com and came up with 5 fault codes.main was this 17705 which aparently means there is summin wrong with my dv or there is a boost leak somewhere.question is, my car wouldnt start the other day(engine was at normal temp and i turned it off for 3 minutes and went to start again and move on and it wouldnt start) but when the engine is cold it will start first time?anyway will this 17705 code cause my car to somehow do this?also got these codes if anyone can help: :ermm:
    16825 - Shareware Version. To Decode all DTCs
    P0441 - 35-10 - Please Register/Activate - Intermittent
    16395 - Shareware Version. To Decode all DTCs
    P0011 - 35-10 - Please Register/Activate - Intermittent
    16705 - Shareware Version. To Decode all DTCs
    P0321 - 35-10 - Please Register/Activate - Intermittent
    17863 - Shareware Version. To Decode all DTCs
    P1455 - 35-10 - Please Register/Activate - Intermittent
  2. Ballcrusher
    Ballcrusher NO CAT JUST 3" STRAIT THREW
    347
    it sounds like the crank case sensor to me. cos mine done the same thing as soon as it was cold it started 1st time then wen was hot no joy.
  3. FactionOne
    FactionOne Administrator Staff Member Administrator
    3,272
    183
