S3 - failed MOT on track rod end
bpascua Nov 23, 2007
  1. bpascua
    bpascua Member
    81
    Hello All,
    My 2002 S3 has failed it's MOT on the Near side track rod end. The MOT center can source one today for £26 and fit it for £45. Does this sounds reasonable or am I being robbed? I dont suppose that will be an Audi part either...
    Thanks for any replies...
    Brian
  2. rodenal
    rodenal Active Member
    1,992
    It's not a terrible price - fitting will only take them half hour at most i'd say so labouor a little high
  3. S3-ROB
    S3-ROB RD350YPVS - Loves 2 stroke oil
    182
    If the £45 includes wheel alignment/tracking then not a bad price, if not then a bit expensive
  4. HTC
    HTC Active Member
    3,428
    9
    Genuine or pattern part?
    I have pattern ends. Mechanically fine, but they look awful as the outside has rusted in no time. Not a problem if you aren't worried about that sort of thing.
  5. bpascua
    bpascua Member
    81
    Should I insist the retrack the car then? - just in case they forget or dont htink its needed....
    Brian
  6. rodenal
    1,992
    the car definately needs the tracking done - just check they've included for it and wont charge extra for this
  7. bpascua
    bpascua Member
    81
    this is disappointing. I spoke to the garage and they said the cost doesnt include the tracking, so now I'm thinking why didnt they advise the car would need tracking? probably because they are monkeys.
    Next they say tracking is a further £23. I argued and they say that tracking would normally be £45. and an hours labour!
    So I'll end up with a bill for £100 to replace a trackrod end - I suppose all I can hope is that they at least fit it and track the car properly....
    Cheers for the replys
    Brian
  8. Aky
    Aky Aky
    1,512
    Fit it yourselfe - it will take 30 minutes uncluding taking your wheels off and then back on.
  9. darko
    darko Member
    272
    had the same thing on mine so though 'i can do that' really wish i hadnt... they were rusted so solid i had to get a friend round with welding kit to heat them up enough to remove. i do drive through france and mountain roads so guess i have seen my fair share of road salt but even so..
    having a go myself left me off the road for 3 days and was really not worth saving the money
  10. Ian W
    Ian W Active Member
    1,058
    12
    Sometimes can be a really easy job, other times you need to crack the old blow torch out.
    Go through plenty of track rod ends on my redtop corsa
  11. bpascua
    bpascua Member
    81
    all done now. I got a bill for £116 for the track rod end and allignment and a further £51 for the MOT. The upside is that I had a suspension creak when I went over speed bumps at low speed that I had been convinced was the ARB or the ARB bushes - it was the track rod end!!!!
    Thanks for the replies.
    Brian
  12. god_thats_quick
    2,507
    I'd say £116 for a new track rod end and an MOT is a bargain, I reckon at Audi that would be at least double, maybe more.
