S3 facelift 8p exhaust help
S3Frosty Jan 8, 2013
  1. S3Frosty
    S3Frosty Member
    51
    Hi all now the exhaust
    first time owning a car with a valve in it ?? If I want to upgrade for a better sound how do i do this ?? Ie can I de cat
    Can I change back box and leave out the valve in the end which opens at 3200rpm ??
    Please help us
    thank you
  2. nluk100
    nluk100 Well-Known Member
    1,101
    206
    You can remove the pre-cat material (nearest the turbo) without any MOT or CEL worries - it will give you 5-10hp and the turbo spools up better.
    The valve needs to be locked open - did mine a while ago and it certainly improved things (both sound and pickup).
  3. br20vt
    br20vt Active Member
    197
    56
    You could go for a catback system which would get rid of the valve, or like nluk100 said lock the valve open. Its a 10 minute job and might liven things up for you :thumbsup:
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    the valve is only pressure operated i believe so no issues with changing system completely if you wanted to leave it out
  5. S3Frosty
    S3Frosty Member
    51
    how do you lock this valve ?? and i take it, you remove the cat, get a drill, or a piece of wood hamer and destroy the insides :)
